ok im looking at buying a front mount intercooler for my r33 and the measurements are 600x300x180 will this fit my r33 series 1 the reason why im asking this is because he says its for a r32 so wondering if it will fit a r33 and also it has 2.5 inch piping is this too small
cheers
Edited by roOts 33
https://www.sau.com.au/forums/topic/269333-r33-front-mount-intercooler/
Roots, can i ask why you are proposing an intercooler which is 180mm thick?
Alot of aftermarket setups use 76 - 100mm thick intercoolers. Having an intercooler this offers no advantage over a thinner one as the atmospheric air does not sufficiently cool the rear of the intercooler.
Also are you running a factory turbo? This seems oversized for use with a standard T28.
I know this doesnt answer your question but this is another element which you need to consider. Dont just buy a second hand intercooler setup which is wrong for your car to save $200
cheers
180mm thick? :)
I dare say the core dimensions you posted are incorrect.
There are several off the shelf kits available from traders on this forum, the majority of which use a core size around 600 x 300 x 76mm, with 2.5 inch piping, which is the standard piping size used on an RB20 or RB25.
roots-james - please ensure you do PROPER investigation before buying parts
Also before starting threads, a quick search and so on.
Logic never hurts either - an 18 centimeter cooler is a little ridiculous when you get a ruler out
Hahaha 180cm!
Why don't you get yourself a mini bar fridge and pop a hose in either end of it. Perfect front mount, may have issue with closing the bonnet though...
Me thinks the measurements are incorrect.
Ahhh mate, i tried mounting 1 on top of my bonnet. Only issue was that it drew too much currect from my Flux Capacitor. :D
