I plugged in a cigarette lighter powered air compressor, and it stopped almost as quick as it started. Now the cigarette lighter doesn't work, I assume it's a blown fuse.
But looking at the fuses located under the bonnet, near the battery all were okay, so I assume there must be a fuse for the cig. lighter inside the dash somewhere?
Any suggestions?
https://www.sau.com.au/forums/topic/269334-cigarette-lighter-fuse/
check to the right of your peddles
this pic is of the G35 (left hand drive) so filp it around and you have ours. (i think)
Thanks V35 Paul, it was where you said. After you pull the flap off, the fuse for the cigarette lighter is just to the left of the impliment provided to pull the fuses out, the 15 amp one.
Had to get some help from my a Japanese teacher at school to save me pulling them all out to check which one had blown.
All working now.
  • 6 months later...
Sorry to bring this thread up again but I am having trouble finding the lighter fuse on my car - a 2001 250GT sedan.
I can't seem to find the fuses as shown in the above diagram and while I found some fuses in the battery cavity, none seem to be for the lighter.
Can anyone advise where I should be looking for the cigarette lighter fuse on the 250GT sedan?
Hmm still don't seem to be able to find it.. Unless I should be pulling apart under the dash.. Found the computer cable and the home it lives but can't find fuses?
*Looking at Chris Rogers* Chris you are around these everyday.. Are you able to help??
Most 12v sockets have a type of fuse attached directly to it, so remove the socket and have a look at the bottom of it, you should see it, basically looks like a thin metal wire that will have a break in it. Its so simple to fix, had a mate that tried to use a compressor and fried his sockets, the workshop quoted him $800 as they apparently had to take the whole dash out blah blah etc. I called BULLSHIT on it, told my mate what to do, so he ended up replacing the sockets himself for a few dollars.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
