Im sure my car is going to hate me after this morning. Had the 33 for about a year and a half and decided its mothers day so what the hell. Mums been looking at buying a small sports car for herself (mx5 mainly).
So i thought i would let her drive the line for a while this morning. Well she hastn driven a manual in about 5 years apparently, needless to say clutch got rode a fair bit but at one point i just about shit bricks she was almost on the limiter riding the clutch, anybody else i would have screamed my head off but she was pretty nervous as it was.
The clutch smell was so bad took 5 mins to get out of the car. All seems good though i got her to swap back with me and took her for a spirited drive. really enjoyed herself.
anyways just thought i would vent that lil
https://www.sau.com.au/forums/topic/269345-my-poor-poor-skyline/
yeah man but still made my heart sink into my stomach hearing my baby screaming and whining like that was like nails on a chalk board.
Ive told mum when she buys her mx5 coz she wants a manual that i will have to re teach her how to drive one properly.
unfortunately shes my mum and i owe her more than a clutch is worth Col. Ran out of work for bout 3 months i did try the whole u break my clutch you bought it thinkin of replacing with a heavy duty item but meh its mum and she enjoyed herself and i had fun scaring her afterwards (nothing illegal for those who may think it).
Told her she will have to come in the car when i start doing track days. :D
nah feels good still surprisingly lol loving at the moment looks like i might get 600ks out of this tank which is bout 100-150 more than normal.
Ok im gonna have to ask, how the HELL do u get that manny k's outta one tank? lol im yet to get over 430 lol
lol i can go from about 300kms from a tank to 400km driving the same and by just adjusting my EBC from 14PSI to the lowest setting which is lower than the actuator so i drive around with the gate fully open all the time and get like no boost and if im trying and getting up around 6k i can just manage to get like 7psi
and if i drive like an old lady as well on low boost i can get up to 500km
no idea mate found out the hard way though ill get 100kms once i hit the E line plus been driving like a lil old lady lately. dont really care how ive managed it but more kms the betta
100k's? Really? haha i was getting worried about driving round the city when my car just about reached the empty mark lol i dont usually let the fuel light come on anyways but thanks 4 th info :)
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
