Hey all having a few issues with my new autech stagea and i bought a consult cable and put the software on my laptop but it wont connect to the comm port.
Also had another diagnostic tool on the car at my local performance shop which wouldnt read it either.
I dont know if anyone else has had this problem but as im just cruising the car surges like i am tapping the throttle on and off. Have change the coil packs, cleaned the afm's put a new fuel filter on but nothing seems to work.
Any help would be greatly appreciated.
Thanks
Ads
Dont think the consult will give you much information regarding your problem that you can't get from a manual ECU diagnostic, give that a try. Work through the usual suspects like, fuel pump & regulator, spark plugs, TPS, O2 sensor etc
What "diagnostic tool" did the workshop try and use? The reason I ask, is because I went through this with my pulsar recently, and after much arguing with the cable seller, along with repeated returns being tested by him as fully operational, I bought one off the ECUTalk guys (NewKleer on here and pulsar.org) I had no further issues.
Just be aware that all consult cables are not created equal. :P
Thought maybe the consult would show any error codes and if afm's and tps are reading properly
Yeah, it will, but you can get same information by doing it manually.
just do a continuity check between the wires on the consult port and the pins at the ECU (forget the check one, check there is 12v when car is on at 12v ign one, gnd to gnd, and the remaining 3 go to ecu).
    • They're supposed to not be compatible.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
