High all, removed my left kick panel to install my new Power FC:D and found this. Looks like stock ECU but has a Mine's plate with serial no. on it. What does this mean?? Has it got a daughterboard or something in it? I know the stock ECU's are locked so what has been done? It will probably be up for sale in the near future once I know what it's worth
https://www.sau.com.au/forums/topic/26936-took-off-my-kick-panel-to-find/
Score!!!
Would seriously consider putting it on a dyno (if you haven't already) to see what the AFR's are like. i.e. make sure the ecu that is installed, isn't leaning out the mix too much due to the better fuel it was prob tuned on. Either way, i'd sell it and have an ecu that more people in this country know how to tune.
Adrian
I have had the car for over 2 years now, runs sweet as. I always thought something was strange because the rev limiter doesn't cut in until around 8,000rpm or higher, and when I accidentally set my bleed valve wrong and boost went off my 20psi gauge the boost cut never cut in. Also I have the car over 220, definitely no speed cut either!! When I go to get the Power FC dyno tuned, I will make sure I get a run on this ECU first.
thats like with my car!
i found this cool little plate with IMPUL racing written on it... it had clamps and looked like it belonged somewhere in the engine bay//
i was like... cool, theres some IMPUL work on my car!
but then i looked down at the pedals and realised that it clipped perfectly over the accelerator, prolly just taken off and put in the glovebox for compiance. not sure if its meant to be for that? but it fits nicely around it, so i now have an IMPUL pedal. anywayz... i got all excited for nothing...
It'll do nicely for a few basic mods - but if you need to do anything too extravegant you'll have to send it back to Japan for repogramming.
Its better than the stock ECU, probably saves you having to buy an S-AFC, but its not the worlds greatest thing way down south.
This topic has been covered previously. May get $600 for it.
It would run lean as the mines ecu is tuned for 100+ octane jap fuel. Even if you just plug in the pfc and drive around and give it a glogging the engine check light will come on as it the base igniton and fuel maps are set for the jap fuel.
yes it would cause slight detonation but unless u know what you are listening for you wouldnt know!
I also have a mines ECU in my R32 GTST...it has no speed limiter...i got the fuel all checked out and it was running lean...but only cos the old fuel pump was stuffed...put in a new fuel pump and she doesnt run lean anymore
i always thought the car ran rich. When I bought the car, it was totally stock engine-wise, but it did have set of platinum plugs in a 7 heat range. Had the head off recently and internally the motor is very healthy. Only ever run it on 96-98 octane fuel, no booster. So all I know is that it ran the car fine in stock trim, and runs it sweet as with a full exhaust, front mount and more boost.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
