Gentlemen, just a couple of quick questions for you, how do i tell the difference between an r33 s2 turbo to an r34 gtt turbo i know they're supposed to have steel blades and slightly bigger rear but how do i check (no blades left on s2 turbo to compare). And also i know the R33 turbos dont agree with higher boost settings due to the ceramic blades so can i run higher boost on the 34 gtt turbo? Let me know ur thinking patterns... cheers
https://www.sau.com.au/forums/topic/269379-r33-s2-and-r34-gtt-turbo/
theres bugger all difference between s2 and r34 turbo
both are ceramic and plastic/nylon compressor wheels
none of them are steel wheel
the r33 s2 should have 45v2 on the front from memory
and the R34 will have a bigger rear housing i think its 0.58 or 0.60 and OP6 may be on there
not sure if thats a VG30et housing spec only or R34 as well, but its about the same size
theres 10kw difference between the two
and both fail above 12psi on an RB25det
You couldnt have put it better, thanks champ
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
