Gentlemen, just a couple of quick questions for you, how do i tell the difference between an r33 s2 turbo to an r34 gtt turbo i know they're supposed to have steel blades and slightly bigger rear but how do i check (no blades left on s2 turbo to compare). And also i know the R33 turbos dont agree with higher boost settings due to the ceramic blades so can i run higher boost on the 34 gtt turbo? Let me know ur thinking patterns... cheers
https://www.sau.com.au/forums/topic/269379-r33-s2-and-r34-gtt-turbo/
theres bugger all difference between s2 and r34 turbo
both are ceramic and plastic/nylon compressor wheels
none of them are steel wheel
the r33 s2 should have 45v2 on the front from memory
and the R34 will have a bigger rear housing i think its 0.58 or 0.60 and OP6 may be on there
not sure if thats a VG30et housing spec only or R34 as well, but its about the same size
theres 10kw difference between the two
and both fail above 12psi on an RB25det
You couldnt have put it better, thanks champ
