Is there anyway easy way to identify if an RB25DET head is a NEO or not, without having to pulling a lifter out?
Lets assume for the sake of argument that it is a bare head with no manifolds, and may have the wrong cams installed so we can't use the CAS drive on the exhaust cam to indentify it
https://www.sau.com.au/forums/topic/269422-easy-way-to-identify-neo-head/
  • Replies 43
Let's break that down a bit:
Theres a number
It's on the exhaust side
Look above cyls 2 and 3
Read the number
Post it here
That's the only 'other' way to identify it unless you want to take photos of the inlet ports.
They are the holes on the intake side of the head.
Thanks Mate, I get where you are coming from now.
Sorry I didn't quite follow at first, I thought maybe I could look at the number and determine if it was a NEO or not without having to post it up, if there was some sort of rule to apply or something. Also I wasn't sure if this number was on the exhaust side under the cam cover, or just above the exhaust ports or something. I'm guessing its not under the cam cover and will be obvious when I go and look for it.
I will get the number and post it up tonight.
Thanks again
On this path...
How can you identify a neo engine when you have the whole engine there?
I don't know of any differences in the blocks. I'm sure there are but I've never done the research on it.
I would say the main differences are going to be on the water pipe directions/configuration. Other than that, they are all identical.
Which means it does not matter if you have neo block or non-neo block....all as good as the other.
You can put a neo head on a 33 block and essentially...it's a Neo.
  • 2 years later...
Yep, thats definitely a non NEO head, You can see the lifters are hydraulic
Pretty sure the NEO head has 05L on the exhaust side. I looked at mine tonight and i can't actually remember lol.
The NEO head has 2 M6 bolts for each coil pack rather than a rail as said above. The NEO has the provision for the head breather on the exhaust side of the head above cylinder 1 but there is no hole drilled for it, just the two threads.
The NEO has Shim OVER bucket lifters. You can easily see them when the cam covers are off. You sorta have to know what your looking at, but you can easily see the shims sitting on top of the lifters.
  • 6 years later...
So I have a stagea that’s blown a head gasket and I’m looking for a head, I’ve looked for the casting number in the place that’s specified and there’s no number that I can see, is it cast into the head or stamped
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
