hi everyone after many months of enjoying the hobby that is awuarium owning it has come time to sell due to the addition of a new hobby to the household (cry cry eat eat poo poo) so i have for sale my complete set up as follows-
Aqua one 620 (90 litre) aquarium black in color on a nice two door black stand
comes with lights, pump and filter inbuilt into the two hood sections, makes for a very attractive unit and gives you the freedom to choose your own biological media for the filter.
Accesories-
gravel, nice thickness on bottom
air pump with valves, two air stones, two different sized flexible bubble walls
$100s of dollars of natural plants including massive driftwood swordplant at back of tank
volcano rocks with establised plants
2 x regular catfish
2 x 6 inch oscar fish, one with some missing scales from a recent tiff both dark in colour
black backgtound
thermometer
vaious suction cups/weights for airlines (to hide them)
all dry food and chemicals (melafix, stress coat, bio booster, plant food etc etc) to get you started
NOTE* NOW also includes brand new in tank uv filter with custom piping to help hide unit behind large sword plant-these filters are designed to kill all bacteria that flow through them naturally ie-no chemicals but the good bacteria is safe in the bio-media in the hood filter
overall this has been a great set up, admittadely not perfect for oscars as the gravity fed hood filter needs cleaning more often than usual due to the size and waste output of the fish for those in the know, was going to whack on an external filter and later upgrade to a larger tank to keep the oscars as i have become very attatched to them, you can pet them when you feed them :blink: but those of us that know when a baby comes some things must go
i have spent a lot of money changing and perfecting this set up over the last few months but i am only looking to regain the cost of the tank and stand so its up for $400 neg
either pm or message me on 0420553559 to discuss prices etc
cheers, ben
sory about the bad pix, cant find my digi so they are off my phone, may also be intersted in swaps for stuff and possible cash adjustment depending show me what you got :(
ok final drop $350 it,s got to go my house settles in two weeks, don't wanna take it with me set it all back up again then sell it so fish will go to a shop and it'll be put in the shed to be forgotten so snap it up, replacement on tank alone is 400 plus
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
