83 Skyline Mr30 Front Seats. Repair Or Replace?
Hi,
I'm looking to repair or replace the front seats in an '83 Skyline MR30. The current (original) seats are badly worn and torn.
Options are:
* pull them out and get them reupholstered - expensive - one auto trimmer quoted around $800 for all the seats (and the car cost less than that to buy/roadworthy)
* wreckers - the MR30 seats I've seen are all in similar or worse condition.
* fit seats from a different/newer model.
It looks like the third option is the way to go. Can anyone recommend seats that will bolt straight in or that can be fitted with a minimum of difficulty? (It's an old car in original condition, so brand new "racing" seats won't suit.)
JohnH
John,
What part of your seats are R/S?
Is your car a Ti or poverty pack??
And don't be concerned about the postage, I might need a favour in Melbourne if your near the east side.
Cheers, D
John,
Cheers, D
Seat and back cloth worn through to the foam. Driver's seat especially. The "mechanicals" of the seat seem to be OK.
I assume it's a "poverty pack" model (nothing special - rear brakes are drum).
I'm in the SE suburbs. Happy to oblige.
regards,
John
  • 3 months later...
To continue the story...
An autotrimmer quoted $800 to retrim the front and rear seats. This was a "minimum" retrim leaving all the vinyl and replacing cloth only. A full retrim would be between $1200 and $1500 depending on the material chosen.
Also considered getting seats from a later model car. First thought was an R31 but the rails are different and other models even more different.
So, back to the wreckers and an R30 ti model that I'd looked at previously. The rears and passenger seat now looked more reasonable than they did before (no rips, no blotches) so have been purchased for about $120.
Now looking for a driver's seat.
cheers,
JohnH
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
