i got your dump pipe put in :D ... its good!! :) and yeah theres definitely a difference but i'm still running about 6-7 psi LOL ... gotta get a ebc ... i think my car is runnin much richer too ... got a question though ... i can't use the heat shield now with the dump pipe in there it will not fit in... theres no way to make it fit is there? so i think i may have to steal that CAI off ya :D also i think i may have to heat wrap the intake pipes LOL ... the other thing i did was put on the teins ... the ride is a bit bumpier but not that much ... i like it :D theres absolutely no body role and corners feel much easier to take LOL :D ... i think eventually your car will be mine steve LOL :D
https://www.sau.com.au/forums/topic/26945-attention-steve-d/
Sorry, no way you can fit the heat shield, thats why the dump was wrapped, to keep the heat down.
If you are only getting 6-7psi, I would expect that you must have a pretty restrictive exhaust - sorry to say. I had 9psi with cat and cat back, about 10 when the dump went on.
The main difference I found with the dump though was not increase in boost, but a really early spool up. I started making boost around 2200-2300 and the mid range felt a bit crisper when at part throttle.
I have the partition here, pick it up anytime. It may not fit perfect, but it would make a pretty good template so you could customise one for your car - easy to make AND CHEAP :D lol
Good to hear the tiens arent kidney jarring - sounds like the same one's Enrico has.
https://www.sau.com.au/forums/topic/26945-attention-steve-d/#findComment-573004
nah i dont' think its the exhaust being too restrictive .. i can't see how it can ... the only way to know is when i get the boost controller really :D .. but yeah the car is definitely 100% better especially now that i got a wheel alignment from bridgestone... free plug for bridgestone at mile end on henley beach road ... the guy was great .. cant' remember his name ... but i went to the one on gouger but it is closed due to renovations and the other guy said that that larry fella who all u guys love has left bridgestone and is now going to be working for the goverment?? ... guess hes following in steves footsteps :( ... but yeah now im taking corner faster without even hearing the wheels screech ... what a difference it makes!!!! :( ... the guy doing my car told me it was way off before he fixed it ... can't remember exactly what he said but it had 16mm toe in? or something like that?? LOL when it should be 2 :D hehehe
https://www.sau.com.au/forums/topic/26945-attention-steve-d/#findComment-573179
I am not sure about more heat wrapping, I only had the dump done and it seemed fine, didnt melt any wires or anything.
If you are worried just keep an eye on it, if anything looks like it is starting to show signs of heat fatigue, wrap it/shield it.
A bleeder shouldnt cost too much, and it will definately help, just dont wind in too much with the stock cooler or you will be needing a new turbo.
https://www.sau.com.au/forums/topic/26945-attention-steve-d/#findComment-573245
well to answer the second part of the question .. they did a 4 wheel alignment using their fancy hardware and computer :( ... notice quite an improvement ... in the morning my tyres were squeaking when i was turnin a little fast whereas in the afternoon they weren't squeaking at all :( and i was takin the corners a little faster since it was like 3 in the morning ...
https://www.sau.com.au/forums/topic/26945-attention-steve-d/#findComment-573832
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
