Injector And Afm Upgrade
Change the pump... Or you'll likely regreg it in 12 months time if it's clunky...
Convert to dual filament bulb FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed. -
If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
