How many RWKW will Nismo 555cc injectors make safely?
47 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi Fellas,
I currently have 312 rwkw and the injector duty cycle is at 81% (using nismo 555 cc injectors), without a FPR
My aim is to get my power up to 360-370 rwkw. Using basic extrapolation ((0.81 x 365))/312)=94.7%), I get an injector duty cycle of around 94.7%.
However, if I install a Fuel Pressure Regulator (FPR), I will be able to increase the pressure, thus, making the injectors flow a bit more.
Anyway, I need you opinion on what power you think the injector's would max out using a FPR with my 555cc injectors.
My tuner is very confident they will make 360-370rwkw safely, as he has done it before.
Please place your vote!
Cheers
You dont need to bump something 45mins after you last posted in it dude...
Just be patient.
Your vote would be greatly appreciated!
Weren't you runing like 365 watts in your R31? What size injectors were you using?
I already have voted.
I used 740's - i knew the power i wanted, so i purchased injectors to suit it. :happy:
Im not a fan of FPR's if you've gotta buy injectors, you might as well buy the correct ones as i see it and use one of the better Nissan OEM parts.
For what you need, it'll be fine however to add in a FPR, bump a few PSI and make what you need.
without bumping fuel pressure your 555cc's would probably max out at around 330-340rwk
So generally speaking, how much more power does a FPR provide?
Also, are there any disadvantages to having a fuel pressure rgulator over bigger injectors? (Does it increase the chance of damage to the fuel pump? Or increase the risk of split hoses? Can a FPR damage injectors?)
    • Yes, an R34 workshop manual is downloadable. The R32 GTR one which is findable everywhere would also do the job, seeing as almost all those bolts are same-same enough.
    • It can be hit and miss, I can fit 15mm ones on the v37, but only because the wheel happens to have voids on the mounting face that allow it to fit. Have you checked the mounting face of the wheel and know it will not sit flush? Rather than cut (or try and find shorter) studs, just buy a thicker spacer (unless clearance from the wheel to the guard does not allow it), then everything is reversible in future
    • Obviously you need shorter studs (don't just cut the original studs off!) and really short nuts that will fit in the spacer. Thus exposing the problems with thinner bolt on spacers.
    • https://www.carsales.com.au/cars/details/2002-holden-commodore-ss-vx-ii-auto/SSE-AD-18219062/?gts=SSE-AD-18219062&gtssaleid=SSE-AD-18219062&pageSource=details
    • does anyone know tie rod torque setting and anti roll bar for r34? Is there a workshop which shows various components torque setting?
