I’m in the process of installing a Boost Controller / Turbo Timer / Boost Gauge. I need to know if my 1990 R32 GTR has a Single or Dual ignition wires.
I have attached the best photos from the installation guide & it’s all the info I have. I’m stuck on where a few wires go if any one can help?
I’m guessing it’s a single ignition so I’m going to following the instructions for the single ignition set up.
I’m stuck on the following wires
The wire that goes between the relay terminal 86 & the Parking brake. Do I join a wire from the terminal to the hand break switch or do I cut the hand break wire & wire that to the terminal on the relay. Basically I need to know if it's wired in series or parallel. I'm guessing it's parallel & it's just to get an earth when the hand brake is applied?
The Yellow wire "switches the unit on & off" & is wired to the ignition this wire I'm really not sure about. Does it go to the ignition switch if so where on the switch. Or can any positive power that comes on with the ignition like the cigarette + be ok?
The Red +12VDC provides power. This wire needs to go to Battery positive does this mean it must be wired directly to the + terminal on the battery so it’s always on or can I wire it to a positive such at the cigarette lighter +
Any help would be much appreciated?
https://www.sau.com.au/forums/topic/269487-r32-gtr-single-or-dual-ignition/
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
