Ok posting this up for my mate.
On the 9th of may APM radiators was broken into. Thieves went through the customers cars and stole various items.
One of the main items was a brand new garret gt35R with a 0.82 rear housing which they opened the bonnet of a soarer, unbolted and stole. We are getting the serial number currently before anyone asks. The car it was stolen off is Benny c's soarer for those of you who know him.
If anyone has any information or sees a gt35r for sale please contact apm radiators on 83846056 or PM me on here and I will pass all details on
Cheers
James
UPDATE:
Stole tools, stereo, afc, rsm, even the harnesses!
They spent a fair bit of time on the car as they undid the manifold aswell to the head! and took that and the wastegate, so if you hear of a 1jz turbo kit with ebay spec manifold, wastegate and gt35r also would like to know!
Theres over 6k worth of things were taken from the soarer alone.
Any help would be much appreciated.
Edited by J_i_m_m_y
https://www.sau.com.au/forums/topic/269493-workshop-broken-into-in-lonsdale/
So let me get this right.......This joint does not have any form of security?? Like i means seriously they popped the bonnet and got the right socket size/spanners and unbolted the turbo and took off with it as well as a few other things they had time to steal?? Or did the alarms go crazy but it took chubbs waaaaay too long to get there??
Good luck getting the bits back and finding them!!
Wouldnt surprise me. Chubb security guards are all fat bastards, so I laugh whenever I hear the name Chubb
Probably doing a very slow patrol around maccas at the time
-D
was outside the workshop due to space and its our mates workshop. never had a problem before as even my supra was there for 13 months unlocked outside and everything. would have taken them over an hour at best case to get the manifold off. and usually theres cars atleast every 5 mins on the road its on aswell all through the night! So someones got to have seen something. and insurance doesnt cover it.
They got into the car, where his tools were and used them to get more shit off the engine.
they are f**king scum.
all the parts are traceable so if u hear anyone getting any of this stuff let me know please :D
I work just around the corner at Total Imports on Saturday and sometimes during the week. I'll ask my boss if he saw anything or knows anything and i'll keep my eye out around the place if i c anything or hear anything i'll let u know. Good luck finding the parts.
    • Sounds like the rack seals blew.
    • ^ This is all good advice. I can imagine that there's some passive components in the HVAC controller that run that PWM output that could die, or suffer bad solder joints. It can be worth opening it up, taking a schmooze around looking for swollen electro caps, evidence of liquid escape anywhere, tracks that have been hot, lifted, cracked, etc. A DMM might not be suitable for seeing if the PWM output is pulsing. Might be too fast and too low voltage for a DMM to keep up. An analogue voltmeter might give a better hope. I use a handheld oscilloscope (<$100 from Aliexpress if you want something cheap). A DMM might see the voltage across the motor flicker. Otherwise, as above. If you can successfully see PWM action, then the control side should be good. If you can't see it with what you have, you might need to step up the instrumentation used, as above. Beyond that, and dbm7's advice on testing the motor directly, you're down to looking for broken wires, corroded connector pins, etc.
    • So Thanks for the comments etc. To follow up on this, we went down the path of fitting a divider down the middle of the external pipe that was added to the exhaust manifold and the divider went from very close to the external wastegate all the way up to the "V" part where the pipes from each side of the manifold joined. After this modification it was finally in a position to do the dyno-tune with some degree of success. Top end power was down about 10kw (250rwkw down to 240rwkw) I believe from previous but it seems to be more responsive lower down and at least it is now driveable and fun and back on the road to be enjoyed. Apparently the timing couldn't be run the same as it was running into knock and boost was down about 1psi. For all we know this could have been from the fuel being a bit older, or perhaps some slight complication from the new head gasket as we didn't have compression figures from before that mod to compare. I'm no mechanic and this is second hand info but I just wanted to follow-up to those that commented or read the original post with interest. After so many months of stuffing around this is a big win. The interesting part was most of the info around this was gained from information around Barra motors and not GTR as the manifold setup on the Barra with single turbo was more similar.  Thanks for those that helped with info. Regards Rob
    • G'day ... first up, I very much doubt that's a resistor network (as used also for this job), but the part# looks right. The description of 'power module assembly' looks to be nissanese for 'PWM driven, ground switched, DC motor speed controller'.... the circuit in the schematic kinda infers that's the case... ...with the transistor symbol appearing in the unit described here as 'Fan Control Amp(lifier)'....being driven by pin20 on the HVAC unit,  and a feedback signal on pin19 from the motor negative terminal for some reason (might be motor fault detection, maybe they detect commutator switching to determine motor revs as well, I dunno)... but if they are  counting commutator spikes, a bad segment (or really worn brushes) will throw a spanner in the works... The motor itself will as said be brushed DC with segmented commutator, rated at 12VDC nominally ~ now-a-days I just unplug them, determine the positive wire, and hook them up to a variable power supply and find out how much current they draw, if they work etc etc ...you can also check for bad segments...ie; set the power supply up to feed 1volt @ 2amp max, then watch the wattage count as you slowly rotate the fan blower motor through a complete revolution ; any bad/dead segments will be clearly evident...some folks would just say determine the positive wire, and feed it battery voltage, and if fan spin, you've got a win...<grin>... well, at least that infers it should do something when plugged back in, and the HVAC unit commands it to run... and if it doesn't, you suspect the module, but you should check the PWM signal on pin20 is actually present, and if it is, blame the module ...
    • Ah. OK. I take it back. I hadn't looked closely at the R33/4 arms and presumed that GKTech did as GKTech do everywhere else, which is to use sphericals there. The poly bushings are made to be 100% interchangeable, should use the standard bolt just fine. Every other bush in every other place in pretty much every other car, does.
