Hi,
I just bough an R34 GTR Vspec. It's stock standard, except for catback impul exhaust and performance air filters.
What are the basic bolt-on mods i can do to get more KW from it? I spoke to someone who said i can increase the boost, get it tuned for the extra boost, and do a few other things (i cant remember what they were) and i could get it to 250 rwkw.
https://www.sau.com.au/forums/topic/269505-stock-r34-gtr-how-to-get-250-rwkw/
Some form of engine management - Power FC etc
Front pipes and a high flow cat if its a crap one.
Run 1bar+ boost and you'll get roughly 230+kw@ all 4 wheels.
Maybe playing around with an exhaust cam gear if you want.
Edited by PM-R33
Hey man,
congrats with the car! pop a power fc on, an ebc and a high flow cat and you should see 250ish at 4 wheels. Mine did the 255 with the mods there and its a great package.
+1 on the stock dumps, they are fine
ps: never stops though, expect to empty your wallet as you hunt for more power!
The simple recipe for 250kw in an R34 GTR is as follows:
high flow cat
good cat back exhaust
14psi boost via decent boost controller (buy one now, you'll need it in future anyway, trust profec B II is good, simple and cheap).
Apexi power FC
high flow panel filter, or pods if you like them
adjustable cam gears
front pipes can do them if you want but they are not 100% needed. but they are easy to change so may as well do them (HKS ones are the go).
get the boost controller, power FC and the cam gears tuned together on the dyno. it will take no more than a couple of hours and net you easily the 250awkw you want. it's a really sweet spot for a GTR. doesn't cost much. doesn't hurt reliability much. doesn't hurt response at all (better than stock) and the car will be great fun to drive. it's basically what you expected a GTR would be like standard!
One other thing I'd suggest if you like driving hard and plan on some track days is get an oil cooler. it has lots of good benefits and will help your RB26 live a long life. :D
And don't expect your clutch to last long if it's standard..
yep, the above mods will get you the 250awkw but if you really want to enjoy it you'll need:
clutch first.
some decent tyres
a few little suspension mods to get the most of the power.
some decent brake pads and fluid
and that should keep you happy for a while. if you want to go harder than that prepare to open your wallet wide.
What is everyones boost running stock? mine with just a cat back and stock everything else seems to sometimes hit 1.1 bar and then hover around the 1 bar point.
Is this common? It seems high to me but the car is basically stock except for a crap cat back
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
