hey alll
i have a red top nics rb20 in my all original hr31 that was running perfect...
but now if i try to slowlly bring the revs up it farts and coughs around alot..
was thinking tps so i swapped it out and changed nothing..
when i first put the motor in the car it ran fine... now just recentlly its gone up shit creek..
any one have ideas??
is this a common thing?
was thinking maybe afm?
cheeers for any help
tom
:happy:
https://www.sau.com.au/forums/topic/269506-red-top-rb20/
alright sweet
i have 3 spare sets of coil packs and a spare cas and spare tps..
already tried swapping over the tps but that did nothing...
il try cas next..
its a nics red top..
cheers for your help guys :whistling:
tom
https://www.sau.com.au/forums/topic/269506-red-top-rb20/#findComment-4592431
i wouldnt bother with a cas..
if it was the cas it wouldnt run. its just an eletronic pick up.. either it picks it up or it doesnt.. simple as it. its not like a coil where it can sorta pick it up enough to run.. doesnt work like that. either it has a signal or not
coil packs i look at.. with a weak spark, its easy to blow it out if u induce enough air
might be afms also.. does it happen under load or just rpm??? example.. foot down to the redline it farts n coughs.. or ur at the redline without having ur foot flat.. just enough throttle to keep it there and still does it..?
https://www.sau.com.au/forums/topic/269506-red-top-rb20/#findComment-4593096
what sensor would cause this.???
afm maybe??
iv tryed swapping over a set of coilpacks but that didnt do nothing...
i cant justify going out and finding a red top rb20 afm if it isnt needed...
as anyone would know parts for these donks are hard to come bye
cheeers guys
https://www.sau.com.au/forums/topic/269506-red-top-rb20/#findComment-4601387
