hey guys
i have to design a car for a make beleive customer in VCD
a hotted up version of the R35
for now it will be stroked to 4.0 litres
twin turbo, titanium exhaust.( thats it as not much engine detail is needed)
but i need detail for the body, brakes, rims
rims will most likley be a mix of ce28n and R35 GTR stockies
body will be either gun metal pearl or spark silver
carbon pumped guards, re-worked intakes etc
would be nice if you guys can voice your ideas and ill try and include it in the design :happy:
cheers!
https://www.sau.com.au/forums/topic/269516-r35-gtr-m-tune-ideas/
nah man, your doing it all wrong!!!
take a daewoo matiz, flare the guards a bit, lower it, tint it, millenium jade body colour, chuck a viper twin turbo v10 (hennessey tuned), 6 spd borg warner transmission, enzo brembos and discs front and rear, titanium exhaust, change rims and tires of your choice - keep rest stock as a rock
now thats a sleeper!!!!
Funny thing is I used to have a Daweoo Maiz Van and I always though it would be an awesome go kart with a BIG engine in the back of it :D
heres the first generation draft of the front
constructive critizism please :)
i know its a bit out of proprtion and wonky but its a draft
its got z-tune style front vents
flared guards
the back will have GT style rear guards
stock wing with a carbon blade
+ heaps heaps more
ill update this thread as i go
are you going to put it into Illustrator and finish on the computer or keep it hand drawn?
if you go hand drawn get yourself a lightbox or just a glass table with lamp underneath... throw some ruled lines on it as well so you get everything straight etc or even trace a pic of an actual R35 and use that as a template
keep laying a new sheet over it and re drawing it, trying different stuff as you go
looking good though, don't forget to try different things and keep all the drafts (they like that, shows how much work you've put in)
maybe try to tuck the spoiler in at the bottom and give it heaps of offset up front so you can see some tyre... R35's can't take much offset up front so I like where your going with the Z tune guards etc... good work, always helps to do projects on stuff your genuinely interested in
thanks guys!
it did come out looking alot better.
ill phtoshop it in the end.
im onto my final draft now.. FOR THE FRONT. i still have the back and sides :P
its got a new carbon lip with R32 GTR style vents in it
it did come out alot better looking then i thought.. mebe nissan can give me a job....
i have exams in 2 weeks
someone help me
yep its definitely getting there... just have a look at the roof line, it needs some smoothing... also might be nice to add some reflection to the windows... put a thick white line through the middle and some warm/earth shades below the line and some cool/sky shades above the line (sorry I couldn't find any examples)
also don't be afraid to really push your shading... work out where your light source is and give the areas in shade a fair bit of darkening... this will give it shape (helping to show the flare on your fenders), especially as you are rendering from side on and not 3/4
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
