sorry if this has been asked before, but i would rather you guys tell me, is there another alternative to castrol tranzmax-z for the box and transfer case for my auto s1??and how much does each take??? im having trouble finding it locally at the moment and just recived the gearbox filter, gasket and o-ring from nissan($102 all up if anyones intrested) and want to get it done, or is there only tranzmax-z available??
any help/info would be awesome,
https://www.sau.com.au/forums/topic/269573-oil/
You can use some good quality Dexron III fluids eg Valvoline DX-3 which meets Nissan matic-D specs. A few others around.
I use http://www.caltex.com.au/products_oil_detail.asp?id=267, excellent stuff, had to buy a 20L drum though, through local caltex.
Works out cheaper in long run after you do box, case and powersteer.
https://www.sau.com.au/forums/topic/269573-oil/#findComment-4588717
There is a kit with a gasket and filter for around $80 but if you do buy one carefully check the filters to see if they are the same, as the kit I was given had a filter which looked right but the intake was longer and I couldn't get the pan back on without cutting off the extra length.
In fact you may be able to get by without the kit as the filter is steel and can be cleaned rather than replaced and if you are lucky the gasket will be unbroken and can be reused (but watch for leaks).
Dropping the pan will only yield one or two litres of atf. To change all of the oil you need to take a hose off the trans cooler and run the engine to pump atf into a container (say 2L). When the container is full pour the same quantity of fresh fluid down the dip stick. Repeat until the oil is clean ( about 12 - 15 L).
n.b. dropping the pan is not a 5min job. You will probably have to support the box and remove the cross member to access all of the retaining bolts and there are some fiddly pipe brackets at the front of the pan.
https://www.sau.com.au/forums/topic/269573-oil/#findComment-4591623
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
