hi guys , i am very new to this forums and i am hoping u guys can give me some idea how to import a car, firstly , i am planning to buy a 2.5l v35 skyline sedan and there is this guys here offer to help me do all the paper work and auction and bidding on the car and everything including the car is going to cost be approx. AUD 12k , is this expensive ? this does include his wage of AUD1100.00 for helping me do all the work . am i getting con here ? if i import myself , will it be cheaper ? and does anyone in wa do it before ? thank u for reading and hope u guys can reply me asap cost i really need a car for my new born baby that going to come out in august :)
https://www.sau.com.au/forums/topic/269590-v35-sedan/
That's pretty much how brokers work - we all charge a flat commission. $12K sounds like a mighty tight budget, although I haven't bought a 2.5 in a while, so they may have dropped that low these days I guess. Feel free to shoot me an email if you want to discuss it further - [email protected]
https://www.sau.com.au/forums/topic/269590-v35-sedan/#findComment-4589451
Hmmm $12k landed and complied is doable, but I wouldn't set that as your goal. If that is your absolute max budget I would usually not say to a customer that that's workable, I'd suggest a budget of $13k or so (an extra thousand dollars will make a huge difference to the quality of car you can get) and then if we happened to get a car for around $12k then great. If you are actually aiming for that price then you will have a very limited selection of cars to choose from, and chances are they will be bottom of the barrel condition-wise. Since less than half the cost is on the car itself, if you can spend just a little bit more you'll get a much better car. At $12k only you're buying based on price and all other factors such as condition will be secondary.
For example here are 2 cars with used car dealers, these cars would probably be slightly cheaper if sourced from auction, so as you can see for aroudn $13k landed and compied roughly you could be looking at a one owner car with 56,000km and records.
http://www.j-spec.com.au/list/index.php?ID=14655
http://www.j-spec.com.au/list/index.php?ID=14656
To give you an idea the last 2.5L V35 we imported was a little over $14k and that was a minter with TV, leather and very low mileage.
https://www.sau.com.au/forums/topic/269590-v35-sedan/#findComment-4589662
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
