If you have a GT2871, they're all worse then that...
If I remember correctly, the series 2 turbo had a front wheel made out of some sort of polypropolene that made it lighter and spool faster, but I could be wrong...
Either way, they're both pretty shit... Brittle exhaust wheels and tiny housings...
i did search and couldnt really find anything worthwhile, but i searched a while ago and i think i read the series II is a little biggER?
Nope, not bigger.
Made of different properties. S2 turbo can be boosted a little more as the material the compressor wheel is made of is lighter and a bit stonger.
Other than that, same shit, different smell.
assumption city
they are basically the same, the s2 cant handle more boost
anything around 12 or higher will kill the turbine, or put it at risk
running 12psi or higher, you are basically saying, i accept if the turbo fails and have $ to replace it
this is same for R33 series 1 or 2
the s2 has a different compressor wheel, but its far from stronger
assumption city
Soooo what's different about it?
assumption city
It's stonger. Search, and you shall find as well.
No, it's not.
Personal experience.
RB25s2 is not stronger than s1. The nylon compressor wheel like to delaminate when leant on too hard.. had one in the workshop not so long ago with lots of bits of nylon missing of the wheel.
I recently sold my RB25s1 turbo, that thing spent a year getting abused at 12psi on my RB20 and another year getting abused at 12psi on my RB30 while also being a restriction, which meant the exhaust housing was getting super hot and the exhaust wheel still didn't fail.
RB25 Neo turbos have a slightly bigger exhaust housing.
I think it's pretty much luck of the draw, boost it over stock and it can fail sooner than if you didn't boost it.
That being said, I still prefer RB25s1 turbos and will advocate them over the later nylon wheeled units.
I'd have to agree with the Series 1 turbos being stronger, but would also say the series 2 spool up faster. But when standard we're only talking like 100rpm or something anyway, it's pretty much instant!
Umm.. Series 1 turbo has a STEEL compressor wheel while Series 2 has a NYLON compressor wheel. BOTH TURBOS HAVE CERAMIC EXHAUST WHEELS.
Oh and doof, of course the nylon wheeled turbo spools up marginally faster.. that was the whole point of the lighter compressor wheel :D
    • Hmm makes things tricky then.  I can't in good faith say, go forth my child and weld in whatever metal you remove in your quest for rust. I very strongly expect that adventure will end in sadness.  But you can't leave the car as it is, you literally have a hole in the roof. Also, I know you think the rust doesn't go much further, but the more I look at those photos, I really think the rust does in fact go much much further.  If you are 100% committed to being the only person working on the car.... stop where you are, hit it with rust converter, fiberglass, body filler, paint work, pretend you never discovered the rust in the first place?  Even if the body was repaired, painting the roof is a pain. Were you planning to use rattle cans to paint the roof?
    • Ok so I will not defend my naivety. I regularly feel like things look easier than they are.  As much as I'd love to, buying another vehicle is out of the question. It was hard to get this car through the family process and we just don't have the room.
    • If your current chain of thought is, I'll go somewhere like pick and payless (or equivalent) and causally remove the bit of roof with your BYO grinder then casually weld that into your car... oof. It might sound easy but you will 100% end up with a warped roof. You say you'd prefer some ugly fab work, but I don't know if your prepared for how ugly this will be lol.  I've seen professional welders do similar but easier repairs and still end up with warped panels.  It is reasonable to assume that from your current skill level, you won't be able to do this cut and paste job while keeping flat panels.  Ok, but we are here to learn. This might be the go... jump on car sales, sort by price, buy the cheapest thing with rego and drive it home. This is your new practice vehicle. If you're thinking of doing the cut and paste job, try it on this car. Cut out the panel (hey it's a perfect fit) weld in the panel. See what you think of the results.  Next thing you could try, practice removing the entire roof in one piece by drilling out all the spot welds etc. Have a crack and welding the roof back on.
    • I've never welded but I own a welder and I've always wanted to learn. In fact I had already looked at a 1 day welding course in Sydney.  I'd prefer some ugly metal fab than anything weak.  I'm challenging myself a lot with this car. For so many years I've just paid other people to do things and I've always been keen to learn and get better.
    • Ok, thats a good starting point.  So before we start.... do you mind if the car say isn't a strong as it was before? My first thought is go excavating for rust. You'll be left with a gaping hole, that will be filled with fiberglass. You could make it look factory pretty easily but yeah, if you never crash it will never be an issue right? Before we look at other options, how confident are you welding?
