G'day all!
I've recently brought a slightly done up R33 GTST T25 . 95 skyline and absoloutly loving it! Only thing is, is i don't know exactly what's been done to it and want to know. I know it's got a bit of turbo work and a nice big HKS front mount and Plazmaman piping and a new heavy duty clutch... but he didn't have papers for any of it. I know that's suss and all but i couldn't resist buying it.
Anyway, i just want to know a bit more of what i've got and what i'm running. I'm a bit down on knowledge for cars these days so any imput or comments would be great.
Cosmeticly she needs a tad of tlc but i will get to that in due time... when i've got money haha.
https://www.sau.com.au/forums/topic/269648-newbie-with-an-r33/
Hey man im a similar situation as I have just bought an R34 GTT and the dude i bought it off told me hes had the turbo high flowed but im not sure how i tell if its really done, other than pulling the thing apart which im not experienced enough to do :D
Yeah i'm only on my L's at the moment. Had a bit of troubles being able to go for my licence. I can go for my p's now but why do that when i wouldn't be able to drive my baby? I'll just stick with my L's for the moment. Until i can take out the turbo i guess.
hahaha, this is fkn funny. Sorry dude to laugh at your expense but who goes and buys a turbo car and then thinks they can take the turbo off and vic roads will go "arrh ok well if you have taken the turbo off i suppose it's all good, just make sure you don't put that nasty turbo back on again!"
Thanks Joshington that was one of the best laughs I've had in a while. Hope you get it all sorted.
Just FYI as well Joshington, there was at least one other thread started recently about the same thing, basically the car's build plate will say that it is a turbo, and that in VicRoad's eyes means that you can't drive it, even if you happen to take the turbo off. (not to mention it's an incredibly daft thing to do lol)
yeah sounds like he jumped the gun....... couldnt wait
the best thing is to sell the damn thing....... go through all the P's....
and then buy something better in the end
you wont regret it in the end
That gave me a good laugh!
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
