idont know if it works the same in vic but in nsw you can get an exsemtion to allow you to drive a turbo costs $75 dollars and one dam good excuse.
correct me if im wrong but i thought it was the same rules for l plates.
my addvise get rid of it before it looks any worse "and it will driven by a p plater" buy somthing else to thrash until you get your blacks.
now thats been said dont take any of this personal but even if you didnt mention the L plates most of us would have guesst your on your Ps or Ls cause you got a lot to learn.
oooooooooooooohhhhhhhhhhh dddddddaaaaaaaaaaammmmmmmmmmmmm thats funny.
does anyone else find it funny that you can drive anything you like to learn in?? but once your liscenced to drive you cant anymore, wouldnt it make sense to have L plate rules the same as P plates?
yeah i agree, I find it hard to see L platers driving their parents v8's and M3's wen all i had to practice on was the racv Corolla lol. I think restrictions should be put on L platers as well, coz if kids are allowed to drive high powered cars, they'll want fast cars on their P's. Either that or they'll wanna go fast. Maybe thats one way the hooning trend starts..
Yeah i'm only on my L's at the moment. Had a bit of troubles being able to go for my licence. I can go for my p's now but why do that when i wouldn't be able to drive my baby? I'll just stick with my L's for the moment. Until i can take out the turbo i guess.
my girlfriend got the turbo taken off her 25t about 3 years ago for the same reason. took it to a few mechanics and majority of them just laughed and said it was not possible, but obviously they didnt know ****. anyway, a few parts were simply replaced with those necessary off a na engine and a few pipes were blocked.
ran ritch as a bitch while it was off but its back on now with no problems. cost about 800 to take it off and 800 to put it back on - got the work done at hills motorsports in sydney. when shopping for a na, we only went down the path of buying a turbo car because we got the car so cheap that it would be stupid not to do it!
it sucks you've driven it before hand though, cos now you'll know what your missing over the next few years! on the other hand, it will give you time to learn to drive properly before you put yourself unsupervised behind the wheel of what litereally is a weapon. if i had my car when i was on my p's i probably wouldnt be here tonight writing this message.
i know it may suck for you now, i've experienced it first hand aswell - but one day i gurantee you'll see that taking access to high performance cars off the kids of today is a ****ing awesome move on the governments behalf.
Edited by KR4-GTR
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
