hey need some help with serviceing the stagea.
how do i get the codes & does any one have the translation?
also where can i get a timing belt, trans fluid & filter.
what plugs should i use? -stock neo.
does any one know the machinig limit on standard disks?
if any one has any tips on 100k service it would be a huge help.
cheers, graham.
https://www.sau.com.au/forums/topic/269655-pulling-engine-codes/
i could think of someone that USED to do 100k services, at a very good price.
did may of them, and speaking from experience, did a fan-farkin-tastic job...
if he still wants to do them, he will pop his head in and put his hand up for sure.
anyone confirm?
I agree with Craig... Never got him to work on my car but what Ive seen him post he sounds like a top bloke and knows his shit...
As for the 100k service I did mine myself and was rather easy.
Timing belt wise just get a Kit with Idler and Tensioner pulleys to suit a skyline.
Trans, transfer, powersteer and attessa fluid use Castrol transmax Z or another good quality oil with a Dexron III rating. The filter is metal I've read of people just cleaning it.
Do the fuel and 02 sensor while your at it. Fuel filter is common 02 get an el falcon one i think it is and put ur plug on it :D
Plugs depends on how much you want to spend. Look in the stag part lists or search for what Tangles (brendan) uses... he raves about the ones he uses dont cost much just replace them every 5 or 10k. Or spend a bit more and get some that last ages.
As for the codes ask in the Stag section and im sure some one will help you out (most likely chook)
cheers, graham.
Joeleo87 can hook you up with a gates racing timing belt kit (tensions, seals etc included)
if you want a mechanic to do it for you, give road & track a go - details in my sig
-D
I vote we bring back ryanrb25.... any +1's?
Noticed he doesnt really post much anymore then saw him trying to sell an IC the other day.
i daresay when he feels like offering his services again, youll see him around more often.
but considering the reasons he no longers offers, i dont think any +1's are gonna bring him back.
just sayin.
yeah I know what he means by he got bored of it....
Im a bike mechanic and used to love working on my own shit every night... Now i get home from work and dont even want to know about the damm things with two wheels! Bike gets alote of love when im not to busy at work though :P
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
