hey all, my suspension in my r33 gtst is relitivly stock, with after market springs that came in the car wish
importing it, and a few bushes replace, since i got the car 2 years ago mainly the rear struts
with really quick sharp bumps they are really noisy, like a clunking noise, get it sometimes from the
front end too, from what i can see theres nothing lose or not right under the car, and iv checked the tops of the struts and the bolts
arnt lose, i have no idea where the noise is coming from, is there any bearings on the tops of the towers that could possibly
be stuffed? if anyone has any sugestions on this id be apreciated.
cheers, Rob.
https://www.sau.com.au/forums/topic/269660-noisy-suspension/
i dont think so, the noise more comes from the rear shelf area, my first thought was the bolts for the top of the struts were
lose, but yea wasnt the case, im tempted just 2 pull the whole rear suspension apart and see what i find, if anything
cheers for the reply, i actually pulled all my shocks and springs front and rear out on the weekend, and yea what u said was right. i got another 4 turns on the front middle shock nuts and aobut 2 turns on the rear, they were lose as all buggery, who ever changed the springs in japan did a shit job of it, there was no seals between the chassy and shocks eitther, so i made up 4 gaskets 2 seal that up and cleaned everything up, turned out my springs are blue! lol never knew, and idea what brand springs would be blue from japan?
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
