ok i know this has probably been brought up in threads before but i couldnt find anything on it but ok i was wondering what i need to do to make my pod filter legal is it just a bracket that is connected to the pod n mounted to the engine bay or something else
https://www.sau.com.au/forums/topic/269662-quick-question-on-car-laws/
in VIC you can either have a pod or cooler, but there are some TMU officers who dont even like you just for having a pod... my friend had a defect for having a pod and it was mounted properly with a metal bracket...
It would be handy to know what state you're in.
I live in NSW, I've been done for pod with bracket, got told to shield it. So i did, and also made a CAI. I suggest everyone to do the same as a pod unshielded just sucks in engine temp air! mAybe not shield it if you don't have to, but atleast get some cold air to it. I certainly felt a diference!
I was EPA +D efected in Melbourne for having a Pod and Cooler at the same time. and I had to pay $567 fin to EPA and attend a EPA test. The EPA test was alright, But I think this fin shouldn't be that heavy. For any one to pay $567 worth of fin based on this sort of matter I think it's a f*ken joke.
Generally speaking in SA, if your pod is securely mounted (mine is screwed in with a piece of metal affixed to one of the original pod filter box screws below the pod) then you will be fine.
+1
I had 2 brackets made up to make it secured down as a mofo.....regency had a look, tried to shake it but couldnt and they let it through.....I think that they wont allow it to pass if the pod moves around hence not being secured....any exhaust place can make up those brackets for you mate......i had mine made up at D&T exhaust and its not that expensive
hope it helps
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
