HEY GUYS
MARK FROM HPI MAG HERE.
I AM CURRENTLY TALKING TO THE OWNERS OF KINETIX RACING AND I AM ABOUT MAKE AN ORDER FOR THEIR LATEST PLENUM FOR THE V35.
I HAVE ASKED HIM FOR A SPECIAL PRICE AND HE HAS ASKED ME TO SEE IF MORE AUSSIES WOULD BE INTERESTED.... THERE WILL BE ONLY 5 AVAILABLE IF ANYONE IS HALF INTERESTED PLEASE LET ME KNOW.
I AM EXPECTING THE PRICE TO BE ABOUT $800
** Newly released Velocity Intake Manifold replaces our older SSV version with many improvements:
* Velocity plenum chamber design - Equal air flow between cylinders
* 12% more plenum chamber volume
* 10% short intake runners for more flow and higher HP potential
* Smoother A/F curve - less tuning required - more consistent power
* High RPM power !! 30.5hp gains at 6800 rpm
* Thicker gauge construction for higher boost - warranty up to 30psi **CLICK ON THE PICTURE FOR DYNO PROVEN RESULTS**
For 2003-2007 350z and 2003-2007 G35 (single throttle body engine models)
We took the very popular SSV manifold and went over every aspect of its design to make the most impactful improvements. As our customers and the 350z/g35 marketplace continue to improve the power potential of their engines, the SSV needed a redesign to accomodate the the higher power output of these vehicles.
The new Velocity Manifold is geared for higher flow and higher RPM power gains. This allows for even larger power gains in the many F/I vehicles out there.
The new Velocity Plenum design maximizes flow to the furthest cylinders by creating a "venturi" effect. By gradually narrowing the plenum chamber , the air speed must increase to satisfy the equation of continuity. Improved flow to all cylinders also means an improved smoother A/F curve that requires less tuning in F/I applications, and ZERO tuning in N/A vehicles.
This manifold is constructed entirely of Stainless Steel, then polished out for an absolute beautiful finished product that looks as great as it performs. We chose stainless because of its great thermal properties, conducting 10X!! less heat than aluminum and eliminating much of the manifold's mass, which greatly helps with heat soak. Stainless is considerably more expensive than aluminum, but the finish shines brighter and longer. The overall manifold SAVES 10lbs of weight over stock! Precision TIG welding throughout, and a CNC cut 3/8" main flange. All mandrel bent runners and charge tube, this manifold rivals the quality of other intakes twice its price.
We improved greatly upon the factory plenum designs. The factory lower plenum creates MANY dips and turns which do not promote good airflow and create turbulence inside your factory intake. We developed a straight shot design, eliminating the twists, turns, and obstructions. We then took each runner and also added velocity stack inlets to each individual runner for even better performance.
This Manifold is a DIRECT replacement and will work with any aftermarket intake. It also allows you the ability to use the factory strut bar, or any aftermarket strut bar. We also have available an engine cover specifically designed for our manifold.
We recommend an A/F tuning on Forced Induction vehicles (turbo and supercharged) after installation of the SSV in order to maximize power and overall engine reliability. Tuning is generally not needed in Naturally Aspirated ( NA ) applications.
Each manifold is supplied with all necessary hardware and instructions. There is an additional port supplied which can be used for boost gauges, etc.
https://www.sau.com.au/forums/topic/269716-ssv-extreme-plenum/
Awesome!
Very keen.
Will there be a deal on the cover that goes with the plenum as well?
i am not sure mate, the guy will be emailing me everything tommorrow morning. the $800 is Aussie dollars and includes shipping charges.... will update for you guys tommorrow.
its listed for $749 on their site which is us dollars, plus you would have to include shipping charges plus GST....so all up this should save each guy who gets one a few hundred bucks.
Hey Guys,
Cut off date is most likely next Thursday. i am still waiting on the final price. i am pushing for $800 AUD
Omce all 6 are ordered they have told it will take about 2 weeks to come in.
Will keep all of you updated once i hear the final price.
Cheers Guys
unfortunately i'm going to have to back out of this one (i hope i dont regret it later).
I need to sit down and plan out the work and parts that i plan to do in future, and this might not be inline with it (i'm looking at the ssr twin entry).
feel free to list me as a maybe, and i'll be interested to see what price you get. But to make sure i dont completely screw your planning dont count me as a definate.
I always wonder when i see manufacturers claim of these plenums about the 20/30/50 hp gain.
This plenum looks good although i'm not sure about the 30.5hp gain ? Maybe on a car with forced induction installed. Be interesting if someone dynos it after install :)
Guys do a search on the Yank forums, these things are not as good as they make out especially for NA applications. I have the kinetix V+ plenum or whatever its called and even with that the car only made 1 or 2 hp more.
The ssv has been known to make less power then the standard one with NA applications, not trying to rain on anyone but rather save u guys $$'s and dissapointment.
i was trying to tell you about it a few posts back.....
    • So my R32 GTST has been sitting around at my old mum and dad's place for a few years now...and it's time to bring it home. Main issue I have is that she hasn't been started in about 5 years or so, so I'm not too keen on just kicking it over and hoping that RB20 reputation for being un-killlable extends to long periods of neglect. My plan is to get it running there so I can move it around,  then get it towed back to my place where I can start working on it properly. The old folks driveway is a bad place to start a project like that. I'm getting old too and also haven't stuffed around with cars since forever, so kinda learning this stuff again. So far I've siphoned out all the shitty old fuel and topped up the coolant (thought it was fully dry but took 2 litres to fill the radiator). Planning on hitting the rusty rotors with some brake cleaner in case the tow truck driver gets a bit gung ho loading it up. As far as oil, it's got plenty although it's now dark in colour and obviously needs a change sooner rather than later. Was doing some YouTube research and was planning to hand-crank the motor from the harmonic balancer with a 37mm socket and breaker bar, removing the spark plugs and spraying some "fogging oil" in the holes but there's not much room to get in there with the radiator fan right up against it. Jacking the car up takes too long and I can't leave it half done between visits. So now I'm was thinking of cranking a few times it using the starter (removing plugs and spraying oil first). Reckon there's any chance it will do more damage that way if something's stuck inside the motor? Should I really change all fluids completely before I go any further? Grateful for any other advice you guys have to get her going safely too.
    • Well, that's just wierd. Amongst a string of seemingly benign introduction and request for help threads, we have this one with a link.... to another, unrelated thread inside this forum. Colour me suspicious.
    • Sorry to say, I think that is a pretty long shot on this forum.....
    • sorry, "info" from Lumley here: https://www.lsvcarinsurance.com.au/about-nrma-insurance
    • So it looks like Lumleys are closing other than in Victoria, with the kind offer that another brand from the evil IAG multi-glomerate (NRMA) might offer insurance under their price and conditions if they want to, as an alternative. Lunmleys was good for us because they covered JDM and USDM imports, had 2 car "stable" insurance (ie, insure many cars but max of 2 can be driven at once), covered mods, reasonable overall prices. So, with them gone, who else should I consider? Shannons is last on my list, we used to be insured with them until we found they were helpful at taking premiums but much less helpful at claim time.
