hey all. ive used velcro to stick my sub to the carpet and put anti-slip matts under the carpet but the sub still moves around alot. ive stuck the carpet to the bare boot bottom but the bottom of the carpet is pretty gay so everything i used to stick it down rips off in a few days [1am so im sorry if it doesnt make much sense]
what can i do to get it to stop moving around?
https://www.sau.com.au/forums/topic/269767-sub-in-r34/
By the sounds you have the box over the spare tyre which i think is a pain as you loose the full use of the boot. What size Subs do you have cause i have mounted mine up on the ledge in front of the traction control unit. I can still get my spare tyre even and have 95% of my boot still. Mine is secured to the parcel shelf with screws so will never move.
https://www.sau.com.au/forums/topic/269767-sub-in-r34/#findComment-4591255
Get two straps with clips. Screw one end to the back of the boot and the other end to the sub box. Con ect and tighten, it'll never move. I've got my car to some crazy angles and mine has never moved.
show me and then do it for me =] lol. usually i do my own stuff but i have no idea how to do this
https://www.sau.com.au/forums/topic/269767-sub-in-r34/#findComment-4593361
Mine looks the same as above but is being held in by straps so that i can still pull it out to get to the spare tyre ^^^
But my sub box is square and fits about the same as well... not really sure if it will work with those tilt sub boxes...
https://www.sau.com.au/forums/topic/269767-sub-in-r34/#findComment-4594074
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
