Group Buy Interest! Clear Indicators / Blinkers
I'm a frustrated audiophile. My "listening room" is also the big TV/movie room. So the stereo speakers are also the front pair for the surround. They are Ascension Summoners, by Adelaide Speakers. The guy who runs Adelaide Speakers designed and built for a couple of the renowned speaker manufacturers that were based in SA back in the day. The centre channel ends up looking a lot like yours. It's the same driver setup as this type But I got him to put them into a sideways oriented cab the same size as the side/rears I got. The fronts are flat down to ~20Hz, so I don't have a sub. This is all driven by a very high end Pioneer receiver - so nice but nothing special. And worse, because the fronts can draw so much power at high volume levels, the bloody amp goes into self protection and shuts down if you turn it up too high. 8 ohm nominal can easily mean 6 and modern consumer oriented amplifiers are not as well reinforced on the supply side as they could be. I keep meaning to do something about it, but somewhat like my earlier obsession with DSLRs and Lenvy, I actively resisted dropping more money in there until the urge decreased. If I keep listening to music at really high volume levels I'll just cut more notches in my hearing anyway. They one at 6kHz is bad enough - I need to behave myself now.
After a few weeks with the new layout, I'm thinking.... Change "Engines & Forced Induction" to "Brooom brooom pssht!" Change "Suspension, braking, tyres and drivetrain" to "Rattle rattle, shriek, crunch". Will be better.
This is untested by me, however, its one of the weird but well known behaviours of polarisation and Quantum Physics, and may be able to be used here. A simple way to check if sunglasses are polarised, is to take a pair of sunglasses you know are polarised, then hold the pair you want to test so that the lenses are at 90 deg, and when you look through the two lenses, it will be black. However, if you take a third pair and hold them at 45 deg and between the pair, looking through all three lenses will be almost clear. Weird, but supposedly true and it depends on the weird behaviours caused by quantum effects.
By robbo_rb180 · Posted
I'll leave this here Owned it for 5 days, changed alignment and its .7 of a second slower than my 180sx up Noosa hill climb. Mca reds, cusco diff and short ratio, e85, some gktech arms, endless pads and Nankang CRS Tyres. I beat a gt3 porsche with an experienced targa driver too.
