Last night i went out for a nice drive only to dsicover that there was a strange noise comming from behind my dashboard ..
sounded like littke critters crawling around in there.....
anyone have any ideas .. i have a feeling it may have somthing to do with my airconditioning.. even though i dont use it cos its broken.
any ideas?
https://www.sau.com.au/forums/topic/269804-gremlins-in-my-dashboard/
Try turning off your climate control completely and see if the noise stops.
There is an actuator in there that makes the critter noises when it is shagged, seems to be fairly common on our aging Skylines.
Fixing it is a real PITA if that's the problem.
Mine does it too, regardless of the climate control being on or off. It's more likely to happen first thing in the morning though... I've been told by a mechanic that it's to do with the vents that circulate the air into the cabin...
Do they circulate fresh air even when climate control is off?
    • I’m running links ecu and an upgraded crank sensor. So I guess I have less chance of this.
    • The stock Nissan CAS gets very messy at high rpm, particularly with bigger cams/springs, and most aftermarket ECUs don't do as good a job of filtering the noise as the OEM ECU somehow manages to do. So you get "scatter" in the timing signals that can be really destructive to the ECU's knowledge of engine position. And so you can get spark firing many degrees early, leading to catastrophic detonation events.
    • So you’re saying pretty safe to put back on the high flow. I guess I will lose alittle horse power which is fine. Never heard of timing scatter? My idle has been an issue running rich since I put on a custom intake with smaller pipings so not sure how it will react to the high flow cat also - would add some more back pressure to the system no?    Thanks
    • I'm pretty sure that HK would only have the same blend all year 'round, but whatever.
    • Just put a Haltech in it. Be aware that there is little extra speed available, so almost any money spent on NA "tuning" is wasted. Far better to spend on brakes, suspension, etc. Be also aware that the auto will die behind a turbo, so a manual swap is not a bad idea. Be aware that parts for these tasks are becoming very difficult to find.
