two reclining sport seats for sale.
matching LHS/RHS pair
black on black on black
steel frame
ADRs etc
brand = SAAS
hold you in place really well, makes your car a bunch more fun if your ass isn't sliding out the window around corners!
v good cond - used in my car for about 6 months but i only drive my car for a few hours every couple of months :)
reason for selling: stupid exa floorpan with extra bracing for no roof = seats sit too high.
They will sit properly in any real car :D
I've bolted my other seats back in.
no rails but the mounts are on the base so it's piss-easy to knock some up.
pics:
any interest please pm me :)
would prefer pickup but i could probably organise a courier if you are that keen..
not faded at all, the car spent 99% of it's time in the last 6 months in a shed lol
They have been covered with slip-on seat covers the whole time they have been installed too.
Located in narangba
PM SENT
Edited by Android 360
mate you have a pm. pls call. will pick up tonight
Holding for Jutto87 pending payment
Still interested? Let me know just in case.. That way I can let you know if anything happens :D
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
