Dont want to sell it as had plans on throwing it on my RB20 and tuning it up with E85. But have lsot access to the person i trusted to do the development work on my car.
So, very low kms and very good condition. The only issue is that the Turbo outlet has been cut from where a 90 deg Elbow (alloy) had been welded to it. Can supply the correct Wiggins clamp that i was going to use on the connection to cooler pipe.
The same turbo made 342rwkws on a friends internally std RB25 whish was running 256deg cams and Greddy inlet. Easily a match for the HKS 3040, and very similar to a 3037 only will make a bit more hp
Only selling because the bills for work on my car are adding up and i cant afford to put any of the partsi have saved up for the car...on the car :)
Asking $2100 ono
Can also supply a Trust Type R Wastegate for $650
https://www.sau.com.au/forums/topic/269843-td06-25g-with-10cm-housing/
Thanks but not really interested in swaps...going through a hate period with cars and just want the good gear gone as it has all gotten too expensive and too hard now i have to find someone else to play with my setup
I am locaetd in Southbank Melbourne and will post pics in the next day or so
Should add if you want a 6boost manifold to go with the turbo and gate willing to do a deal on all 3. Manifold is brand new and flanged to suit Trust series of turbos, of course you then have the above mentioned near new gate and turbo.
Would make a killer 340rwkws etup on an RB25 or a pretty crazy RB20 :P
PMs replied, to clarify for all, when i purchased the turbo mid-late last year the original seller claimed 4,000odd kms . The condition of the hot side and turbo in general confirms it has low kms on it.
And if you are after a price for the turbo, gate and 6boost manifold then i will take $3500 (Basically , $1100 manifold, $1900 turbo $500 for gate)
  • 3 weeks later...
  • 1 month later...
  • 6 months later...
  • 6 months later...
So new manifold, gate and turbo setup are on the car and this gate was not used. Lke new condition as can be seen from the pic. Only ever used for some dyno pulls when comparing setups
Hoping to get $650 for it. (TD06-25G is not for sale...unless you are really keen and going to make an offer too good to refuse :) )
  • 3 weeks later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
