i know theres a few threads on exhaust here but im going to do an exhaust on the 260 shorlty... im just wondering what i need? dumps, front pipe, and cat back... ive gutted my cat already. do i want the split dumps from just jap?? its 399 i think for them and 299 for the front pipes?
cheers :whistling:
ps i think the jap styling with the 260 may need a cannon but im not 100% keen :S im really unsure what tip i want? twin tips maybe?
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/
just had my front muffler removed today and replaced with a straight pipe.now it goes- advance dump/front pipe,gutted cat,straight pipe to a magnaflow cannon.sounds lovely and decibel tested it at the workshop,it made 92.8 @ 4000rpm.very happy with it now!
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4592533
cheers :)
There is nothing wrong with the JJR dumps and front pipes, there a copy of the HKS ones and are fine, just make sure the flange face is flat before fitting.
A mate had a set on his 32 GTR with 2860-5's, fitted up fine, with JJR front to, did 455rwhp @ 20psi, so worked fine to.
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4594779
If you do a search on here quite a few people have mentioned that the stock GTR dump pipes are quite good. My 260RS has stock dumps, 3" Apexi front pipes, 5" cat, 3.5" cat back with 2 mufflers. The rear muffler is a Fujisubo Jasma cannon. It has quite a nice sound and is not too loud.
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4595631
JASMA = less than 95dB
So depending on where you live, this can be fine or could cost you an EPA fine and a defected car (like in Victoria :P )
Edited by iamhe77
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4595819
cheers :D
I have the dumps and front pipe for less, front pipe is used like new and dumps are unsed.
pic
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4597888
So depending on where you live, this can be fine or could cost you an EPA fine and a defected car (like in Victoria :blush: )
Awesome. I did not know that. Hopefully with the 2nd muffler it would be under the limit.
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4598539
