can anyone recommend a someone in sydney to tune my r33 and new apexi SAFC 2???????
and also whats the average cost? keeping in mind i will install the safc myself.
also where is a good place to mount the safc?
https://www.sau.com.au/forums/topic/26987-safc-tuner-in-sydney/
i suppose anyone with a bsic tuning knowledge could tune it. its quite easy.
But you'd need a dyno.
So you can change a setting, then see its result, then over and over again.
so contact someone with 2wd dyno and off you go.......
Unigroup engineering can dyno tune your safc. I can highly recommend them. I mounted mine on the dash above the air vents.. but if you want a more discrete look try in front of the DIN slot or to the left of the steering shroud above where your left leg goes.
Check my sig for unigroup details.
ok thanks guys.
firebladejr
which suburb is unigroup engineering in?
and i really dont want to mount the safc on top of the dash cause i dont want any holes/marks ect on the dash, and to the left of the steering shroud (above left knee) is where my gauges are mounted.
any other surgestions?
S-AFC mounts with double sided tape so you don't have to worry about holes in the dash. But the stuff that it comes with is pretty crap, I replaced it with better stuff that didn't keep falling off.
I mounted mine above my left knee under the dash. It looked really good there, like it was part of the dash.
S-AFC tune usually takes around an hour. They tune the whole car, no other way to do it. You get a dyno printout.
You will still have a stalling problem, nothing I know of other than a HKS idle controller will properly eliminate this problem. You might notice some improvement after the tune but it won't be perfect.
  • 4 weeks later...
ive tried ringing unigroup but always get an answering machine. left my details 2 weeks ago and still no reply. been calling them since but just get there machine..........
  • 4 weeks later...
tune takes one hour. They charged me $120ish and ran it o na dyno about 8 times. Included dyno graphs as well.
Check their website in my sig for more details.
What do u guys think of the TSI setup instead of getting a PowerFC. Would u get as much power out of it??
www.unigroup.com.au
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
