can anyone recommend a someone in sydney to tune my r33 and new apexi SAFC 2???????
and also whats the average cost? keeping in mind i will install the safc myself.
also where is a good place to mount the safc?
https://www.sau.com.au/forums/topic/26987-safc-tuner-in-sydney/
i suppose anyone with a bsic tuning knowledge could tune it. its quite easy.
But you'd need a dyno.
So you can change a setting, then see its result, then over and over again.
so contact someone with 2wd dyno and off you go.......
Unigroup engineering can dyno tune your safc. I can highly recommend them. I mounted mine on the dash above the air vents.. but if you want a more discrete look try in front of the DIN slot or to the left of the steering shroud above where your left leg goes.
Check my sig for unigroup details.
ok thanks guys.
firebladejr
which suburb is unigroup engineering in?
and i really dont want to mount the safc on top of the dash cause i dont want any holes/marks ect on the dash, and to the left of the steering shroud (above left knee) is where my gauges are mounted.
any other surgestions?
S-AFC mounts with double sided tape so you don't have to worry about holes in the dash. But the stuff that it comes with is pretty crap, I replaced it with better stuff that didn't keep falling off.
I mounted mine above my left knee under the dash. It looked really good there, like it was part of the dash.
S-AFC tune usually takes around an hour. They tune the whole car, no other way to do it. You get a dyno printout.
You will still have a stalling problem, nothing I know of other than a HKS idle controller will properly eliminate this problem. You might notice some improvement after the tune but it won't be perfect.
  • 4 weeks later...
ive tried ringing unigroup but always get an answering machine. left my details 2 weeks ago and still no reply. been calling them since but just get there machine..........
  • 4 weeks later...
tune takes one hour. They charged me $120ish and ran it o na dyno about 8 times. Included dyno graphs as well.
Check their website in my sig for more details.
What do u guys think of the TSI setup instead of getting a PowerFC. Would u get as much power out of it??
www.unigroup.com.au
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
    • Which I agree with. I don't want or need a high hp straight line car, I want it to be fun on the road and nothing more. Hence why I said my max power goal will be around 500 crank. The few times I drove the car last year I didn't even use high boost and it was already quick enough for me, should have been around 380-400 crank I think (2860-5s at 1-1.1bar).
