Hi all
looks like my oil pump is about to give up after 19 years and 68km. We had the oil pressure guage on her today and its looking like its time to replace it. At idle its at 28PSI and at 3000rpm its at 40PSI and never goes higher.
The motor has the following comp 145 145 145 150 150 150. Bearings arent at all noisy and it doesnt go through any oil between changes.
While the engine is out is there anything else worth doing so i can try and make to motor reliable for a while longer? Im not after huge power. Its got just over 300kw on 18PSI (unopened internals with Nismo turbos and usual supporting mods) and i'm more than happy with that power.
So far Im contemplating sump extension and baffle, oil restrictor, water pipes changed, oil pump of course.
Also, approximately how much can i expect to be charged for the basic engine out, oil pump change and engine refit?
thanks heaps for any advise
MAtt
Check the bearings whilst its apart. Low pressure can and will be worn bearings as much as it is the pump.
Id recommend buying the best quality pump you can afford. N1's are common but the nitto pumps are far better.
First things first, if you are using the factory oil pressure gauge, it might be worth unplugging it at the sender (it's near the oil filter) and giving it a good clean, they are known to give incorrect readings when dirty.
what are ACL bearing like? any good? any other type worth considering?
Yeah i was really hoping the sender/switch was dirty and this would fix it however we had an external pressure guage attached and it was defintely the pressures mentioned above :D
Could be an option for the n1 oil pump or std with the billet pump gears available locally? everyomne seems to use the Acl bearings..
off topic whats the r36 like to drive? i've had eyes on a 32 for a while but the 36 seems a bit more practice?
the R36 is a brilliant car for its purpose. The interior is very appointed, seats are absolutely magic, the engine is capable of providing a good level of fun with great touque spread and the DSG gearbox is great. Besides the nose being a bit heavy causing initial understeer on corner entry its a very capable car. this can be fixed with a Haldex controller. Its amazing how many people comment on it. I got a black wagon and i think it looks the business too.
i bought it as the family car so my wife drives it most of the time with our 18mth old. I showed her the launch control feature the other day with our daughted in the back and they both loved it, so did i.
you will be surprised how much discount you can get at the moment. I got just on 20% off RRP which made it too compelling for me. R32 is a sweet thing as well saying that.
I got a quote to have the engine removed and reinstalled, oil pump replaced with N1 pump and some gaskets replaced. Labour 12 hours for everything. $1800. is this reasonable?
if you have the engine out, i would seriously strengthen your bottom end, i know your not up for big power but, why not have that piece of mind, better to be safe than sorry.. even if its just new rods, keep the standard pistons, they should be fine, its the rods that need to be stronger at that powerm, and also bearings are a must, even if they arent noisy.. n1 pump is fine, have seen them on nearly 400rwkw motors and no problems.
There is absolutely no need to upgrade rods at that power level. You could upgrade pistons, especially if the bores are a bit worn. I would pull the crank out and have it linished with a crank collar fitted. There is no point fitting a new pump without a collar. You could fit an aftermarket balancer to improve the life of the pump. If it doesn't see excessive revs/rev limiter then the n1 pump with a collar should last fine.
OIl restritors are about the only thing i would add apart from the new bearings of course.
Yeah i was really hoping the sender/switch was dirty and this would fix it however we had an external pressure guage attached and it was defintely the pressures mentioned above :)
King bearing are my choice atm, used to use acl's a few years back... the kings are far more crank friendly.
great advice. thanks all.
Does the crank have to be removed to have the crank collar attached?
Thinking about doing bearings, N1 oil pump and crank collar, oil restrictor and sump baffle. Was going to consider doing pistons too but was told the head should then be removed and more to get the pistons in.
crank will need to come out for the main bearings anyway. you probably could fit the collar with the crank still in the bottom end, but certainly not easy if the engine was still in the car. far easier to do it when the crank comes out.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
