Hi everyone,
I've had to start a new profile because i forgot my password & the email i used for my registration has now been closed...
Note: i have searched but nothing specific enough was found.
I recently (November 08) imported a 98' R33 GTR from Japan myself. Car is in perfect condition & usually runs perfect...usually. I'm not new to imports, ive had a TT supra, SR 180sx, 2x R33 Gts-t's etc over the last 6 years so i know the usual things to check.
So, like i said, the car runs great most of the time, but sometimes it just runs bad all of the sudden. It's like the car wont rev but the turbo's still spool & make boost (currently set to 14psi via EBC) the exhaust note also gets louder, sort of sounds like its is blocked off. When this happens i pretty much have NO power and the fuel smell in the cabin gets worse & car also back fires alot. the car does NOT misfire, this is not a coil/fuel pump/spark plug etc issue, all of that has been checked.
I then thought this could be an air flow meter problem until i checked them and noticed they were like new, i even opened them up to check the solder on the connectors and they were perfect.
Me and my mechanic have been over the car several times for vaccum leaks but there isn't any.
I know the car is running very very rich because it is getting between 250-300km from a tank so it does need to be dyno'd but i was just seeing if anyone on here has had any similar issues??
I just find it very strange because it is so variable.. it doesnt matter if its hot or cold or a long drive or short, it can just happen at any time but when it is running good its like a brand new car??
The car has had some significant mods in japan, most of which were removed including the full cage, turbo's but the cams remain (not sure what else has been changed internally) and the aftermarket ecu was removed and replaced with a stock item so i'm not sure if this is contributing to it.
Any help would be greatly appreciated.
Thank You.
James
https://www.sau.com.au/forums/topic/269921-onoff-running-issues-r33-gtr/
Since it's had significant mods done to it, I'm guessing it has aftermarket bigger injectors.. genuine GTR injectors (from the R32 GTR at least) are black and yellow. I would check if you have indeed have aftermarket injectors, look into getting an aftermarket computer like say the PFC or the cheaper Nistune option (you will need to research it, as I believe you need a R32 GTR ecu to run the Nistune setup as I haven't heard of anyone using running Nistune on a 33 GTR ecu) where you can set the correct injector size.
Hi, i thought bout this but the compliance workshop reckons the injectors are standard but i think it might be worth checking, cheers.
coolant temp sensor will keep the car running in the cold map = rich and will also from revving out too much
(on my 32 gtst it limits revs to about 4-5k prm when not fully warm)
i am also experiencing similar problems with it but been too slack to change the sensor (dam uni work :D )
so i would give that a go, the tend not to like working after ~15 years of abuse lol
  • 5 months later...
Im not sure if you've managed to solve this problem yet, but it sounds like your igniter/coil packs could be on the way out.
My R32 GTS-T did a similar thing, i would be driving along, accelerate & the noise would increase, boost would build, but power just wasnt there, & you could feel the power dropping off as if there is no fuel there or something. Changed my igniter, & the coil packs for a set of split fires, & suddenly no more dramas. My car actually feels to get more top end grunt over 5000rpm, where as before it was dropping off from 5000rpm upwards.
Mine was only doing it on long drives where it was up at operating temp for half hour plus, but your igniter could be the problem here....hope this helps.
  • 10 months later...
Hey Mate,
Did you ever get this problem sorted.... I have an issue with my GTR which sounds exactly the same as what you were having and i was hoping that maybe what fixed yours will fix mine.......
Thanks
Michael
Hi everyone,
Thank You.
James
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
