Immaculate 93' R32 Gtr
THERES IS NO ASKING PRICE FOR THIS IMMACULATE GTR.
WILL SELL TO THE OFFER THAT APPEALS TO ME MOST.
you all know what it is worth so DO NOT put a ridiculously low bid.
Genuine offers only!
car needs to go, owner has other commitments
1993 model r32 gtr, original grey colour in immaculate condition. No scratches or dents. rarely driven. allways serviced with the best oil's and coolant. 150,000 klms and reliable!
P1buddy Club wheels 17x9.5's
DBA 4000 series slotted rotors with green stuff pads
Bilstein coilovers
CUSCO castor adjustables
CUSCO camver adjustables rear
Midori upper adjustable camber arms
APEXI Power FC with hand controller
HKS type-S engine oil cooler
HKS Fuel rail
HKS 900cc injectors
HKS primary exhaust pipes
HKS Cam Gears an Gates Racing belt
Tomei cams
n1 turbo's
Sard Fuel Reg
braided hoses throughout!
Alloy surge tank
Walbro Fuel pump
External Bosch 700hp Fuel pump
Splitfire coils
Brand new crank angle sensor
Brand new ignition module
Brand new ignitor harness
Brand new Z32 airflow meters
Brand new APEXI Super suction kit with Z32 plugs
Custom advan airbox
New N1 water pump,timing belt idler, an adjustment pulley with new half moon cam seals
PWR Radiator
Nismo strut tower Brace-Front
Jun metal Intake gaskets
twin HKS Sequential BOV's (hidden in gaurds)
HKS wastegate
HKS FMIC with HKS hard piping 600x300 by 110
TRUST Clear timing belt cover
5 Puk Jim Berry Clutch(heavy duty single plate)
New nismo slave Cylinder an Pivot ball
Greddy Exhaust temp gauge with memory recall
Greddy Boost gauge with memory recall
Greddy A-Pillar Dual pod gauge holder
Greddy Profec-B eletronic boost control
Greddy turbo timer
latest cobalt series Autometer monster tacho
Blue led dash lights
Sparco Racing - driver side
Sparco steering wheel
i might of left some things out but have reciepts for $$$$$
Car has made 320awkw on 1.1 bar can make more power but this is perfect for street.
it has ran a time of 11.6 at WSID on premium unleaded.
Located in sydney.
I WILL BE PUTTING THIS CAR FOR SALE ON OTHER SITE IN 1 WEEK
so you guys have the first preference now, dont waste it.
 Share
    • Big claims here.  Any links up on the website ?
    • If your HP goal is reasonable and you are not drifting. Buy a new R34 box.  If the above is not true, buy a wrecked R33 box and put a gearset in it.  CD09 are not as strong as you think and the cost of / mess around of the conversion puts you in gearset territory.    Also the deal above is awesome,, get that
    • Just got back from a little hands-on with a G58 Baron....I was thinking about this... ..best I can figure it, that pinny was tail-ended ...I didn't really think about the wiring, because all that mattered was the tank and pump cradle (I think I mentioned the pump itself I couldn't vouch for)...which didn't matter, as you said you'd be replacing the pump anyway.... ...'for some reason'....and I imagine this is the panel shop's doing... they've replaced the cradle wiring with a metre of 7-core trailer loom, and attached the loom plug (from a different car) to that. The actual cable run from the top of the pump cradle, to fuel pump harness end in boot, is maybe 60cm in length...so I've no idea why they did this... ....the connector in the boot of the pinny, is not going to help you here...because in theory, it should still be present on your car. On top of that, because they've done what they did, we have no idea which colours of the trailer cabling, have been connected to what on the fuel pump cradle (pump +/- , shield, fuel guage/low-level senders)... ...this means, best approach is to remove the pump cradle, and re-work it now ...not later. That is, if you were going to replace the pump, do it, replace the soft lines at the same time...and sort the wiring out (replace that trailer cable with the wiring loom off your old cradle)...
    • Well, maybe not. The main feature of Chinese manufacture seems to be incredibly variable quality, coupled with an apparent willingness to find a way to see even the stuff that fails QC. So the military could still take the cream of the production run and somehow sell the "sellable but not really useable" stuff to the stupid round eyes on the other side of the world.
    • Have you adjusted the clutch pedal rod? You can wind it in to shorten it. Just can be a cnut to get to.
