Rotary As A Daily Driver?
  • Replies 42
Are just as reliable as a piston engine when stock or modded correctly. They are an old car so if restored/rebuilt or looked after should be fine.
I wouldnt want one as a daily, too good. Maybe a rx7 series 3
Edited by pos513
basically i would really like a mazda rx 2 3 or 4.
how reliable would they be as a daily driver?
Same as any other car.
So long as it has been serviced regularly and doesn't have an obscene amount of ks it should be fine.
Have you considered how much fuel a little 1.3ltr rotary guzzles? They're not the cheapest daily.
yeh i've heard they're rather costly on fuel, just never an accurate amount, i'm currently getting 350k's to a 68ltr tank at the moment.
I've heard they're similar to a V8.
Quick fun little machines, But have you had a look at the sort of money people are asking for them these days ?? If getting a rotary is a must then I would be going for an earlier RX7 . even the series 6 are not that expensive anymore. As for fuel economy an old friend I had used to own one. We are talking V8 like fuel consumption here.... Are you sure you want a Rotor as a daily ? They really are more of a weekend fun machine
Have owned a couple of RX-7's. They are thirsty (but frankly I couldn't care after owning several stroked V8's) plus all the other things that people generally associate with rotarys i.e. smooth, revvy etc.
I will say this though: a good, well maintained rotary is reliable. Poorly maintained or owned by someone who is not an enthusiast will result in a short engine life, more so than a piston powered car. For instance treat a rotary like a VN and boy oh boy is it not going to last long.
However that said between all of the rebuilds I have done rebuilding a rotary was the cheapest (compared to just about all the piston engines I have had aanyway) and for that rebuild I paid someone to do it (not having dealt with rotaries before).
I love them its just a love hate relationship and sometimes the hate wins out.
my old s4 rx7 averaged about 22o-250k to a 60lt tank not the most frugal thing as a dailey driver.
woah, hahah that thirsty. still be worth it, i won't it to be reliable as a daily driver but not primarily as one.
any of the rx series are shit hot
mate i had mine for two years and didnt have a problem with. it was a dailey driver.......... the tps switch played up but got that sorted and it was fine... i honestly wish i dint sell mine. great drivers car.
9yrs ago i used to own a ser2 rx7 running a ser4 13bt. Bought it for $5500, sold for $4500. wasnt a bunky by any means. Price 2day for them has skyrocketed as there getting harder to come by. wish i had kept it.
Awesome lightweight and addictive to drive machine. with 209rwhp (stock turbo @ 12psi, 3" TBE, old school wolf 2d) i ran a best of 13.9 @ 173km/hr (note traction was a problem but good top end). Reliable if properly setup and VERY easy to work on. Definetly weekend only car IMHO. rebuilds are cheap/easy as pointed out above. My advice would be a later model car for a daily as pointed out above.
check out www.perthrotary.com
To the OP, if you need to ask this question, you really shouldn't be buying one.
I'm sorry, but an old-school rotor is probably one of the worst daily drivers you could choose.
The cars themselves are fine, reality is there a typical old capella or 808. Ususal old car stuff to worry about like rust and wear and tear, wouldnt be a problem on a good one if you spent the coin on it.. Theft and parts availability is the real drama, have a look what front and rear rx-3 parts sell for on ebay.
I drove my mates b1600 around for 6 months, made 400+hp at the tyres with a later model 13b, dowelled big throttle body, microtech and a tv51 truck turbo, the thing turned tyres in top gear as it came on boost and kept turning them past 200kph, it had a 80 Litre tank and used to average around 450km's to tank, that said we rebuilt it 3 times in a 2 year period and it probably got such great economy cause it was just to fast on the street...
Edited by NA_R33
 Share
    • OK, next order of business, very much not important but I didn't like how like how it looked (and, we can pretend it restricts airflow if that makes this better). Both the front number plate, and more importantly the holder are pretty ugly. Step1, replace bent old plate with new one in blue cf style with new values Step2, unlike the Leaf where the bumper was flat enough to remove the holder altogether and just mount it on the bumper, with the v37 I decided to chop the hell out of the mount to retain the flat mounting surface. Step 3, much better (needs black bolts I think)
    • If you are selling an R32 GTR, you can buy 3 or 4 v37s Redsports..... Anyway, a few more services/mods for daily use are the first order of business. I'm using the 2015 Q50 (LHD) workshop manuals from Nicoclub and they seem pretty much right, but a search didn't turn up any mention of the term "glove" so I could work out how to properly change the cabin filter for the AC. After some stuffing around, turns out Nissan now call it a "grove" box. Anyway, for anyone who does want to change their cabin filter : 1. Half open the glove box then push upwards each side to release bottom hinges, then twist sideways to remove opening stoppers, then pop off dampener string LHS 2. Unclip the cover behind, then unclip the cover behind that 3. Cabin filter is now readily accessible, note the airflow arrow points downwards. It seems loose in the space but note the cover has tabs that will push it up when you install the cover This time the filter was basically new so I've just marked it with the current date and reinstalled, and the aftermarket replacement I bought Wesfil (WACF-0177) is into the parts box   I really recommend checking this in any car that is new to you, they are normally really grotty
    • I got tools but nothing special, your typical <100 piece toolset ahaha Though, I've never touched CV's before, and dont want to f*ck it up either... I've never taken my car to a shop before (I usually do everything myself or ask the ole man for help) so appreciate the advice on that, will probably stay away even more now. Regardless, any recommendations?  Planning on going to the suspension shop in Rydalmere sometime soon after fitting the coilovers & cv's too for a good alignment.
    • Although, if you're in south-western sydney, i highly recommend you stay away from any shop on Hoxton Park Road.
    • CV's aren't' hard to rebuild, if you don't have the tools then yeah, throw it towards your nearest garage. Any half decent "mechanic" can rebuild a CV, it's quite common to do since there are millions of FWD cars about.
