r33noobie Posted May 13, 2009 Share Posted May 13, 2009 Hey guys, i have bought a r33 gtst and wen i start the engine i need to gas it or it dies, also when it idles i need to gas it or it dies but the problem fixes itself when you drive around the block. However, wen i turn off the car and turn it back on the same problem occurs but takes less time to fix itself. I just bought it so im still pretty noob about these things i've done some researching but i can't find anyone with my problem. but maybe i just didn't search hard enough. Well anyway any help would be much much appreciated! as far i know the car has got its ecu remapped and the old mods are not there maybe thats it?, others have told me something bout the idling sensor? Cheers Link to comment https://www.sau.com.au/forums/topic/269939-skyline-has-bad-start-up-stalls-if-u-dunt-gas/ Share on other sites More sharing options...
iseekool Posted May 13, 2009 Share Posted May 13, 2009 Hey guys, i have bought a r33 gtst and wen i start the engine i need to gas it or it dies, also when it idles i need to gas it or it dies but the problem fixes itself when you drive around the block. However, wen i turn off the car and turn it back on the same problem occurs but takes less time to fix itself. I just bought it so im still pretty noob about these things i've done some researching but i can't find anyone with my problem. but maybe i just didn't search hard enough. Well anyway any help would be much much appreciated!as far i know the car has got its ecu remapped and the old mods are not there maybe thats it?, others have told me something bout the idling sensor? Cheers Check your air temp sensor and afm. Link to comment https://www.sau.com.au/forums/topic/269939-skyline-has-bad-start-up-stalls-if-u-dunt-gas/#findComment-4593502 Share on other sites More sharing options...
yUBER Posted May 14, 2009 Share Posted May 14, 2009 Hey guys, i have bought a r33 gtst and wen i start the engine i need to gas it or it dies, also when it idles i need to gas it or it dies but the problem fixes itself when you drive around the block. However, wen i turn off the car and turn it back on the same problem occurs but takes less time to fix itself. I just bought it so im still pretty noob about these things i've done some researching but i can't find anyone with my problem. but maybe i just didn't search hard enough. Well anyway any help would be much much appreciated!as far i know the car has got its ecu remapped and the old mods are not there maybe thats it?, others have told me something bout the idling sensor? Cheers I had the exact same problem on my R32. I got a new fuel pump and it fixed the problem. Link to comment https://www.sau.com.au/forums/topic/269939-skyline-has-bad-start-up-stalls-if-u-dunt-gas/#findComment-4593783 Share on other sites More sharing options...
barnoon Posted May 14, 2009 Share Posted May 14, 2009 How long has your fuel filter been on for? Might want to change that. Link to comment https://www.sau.com.au/forums/topic/269939-skyline-has-bad-start-up-stalls-if-u-dunt-gas/#findComment-4593825 Share on other sites More sharing options...
Hydroxinol Posted May 14, 2009 Share Posted May 14, 2009 I had the exact same problem on my R32. I got a new fuel pump and it fixed the problem. +1. Had similar issues with my R32gts-t. Replaced fuel pump + filter, problem solved. Also might be worth checking your AAC valve. Link to comment https://www.sau.com.au/forums/topic/269939-skyline-has-bad-start-up-stalls-if-u-dunt-gas/#findComment-4593833 Share on other sites More sharing options...
r33noobie Posted May 14, 2009 Author Share Posted May 14, 2009 thanks guys, i'll look into it. but could it be the tune like the previous owner said ? Link to comment https://www.sau.com.au/forums/topic/269939-skyline-has-bad-start-up-stalls-if-u-dunt-gas/#findComment-4594580 Share on other sites More sharing options...
