Hi guys!!!
Gods_Gift
 Share
Just introducing myself and saying a big hello to everyone!! :D
I only just recently became the proud owner of a '93 R33 GTS-T...after having written off my last car. Long story but it gave me the excuse to finally buy a car i really wanted!! :(
Its needs a good bit of work to get her to where i want it...pretty standard as is. But in very good condition inside and out. So i will probably be on here a bit calling out for help!! :rofl:
Looking forward to getting to know some of you guys and gals, and perhaps meeting you in the near future.
Cheers! :cheers:
Gods_Gift,
Glad to see you made it, the guys and gals in here are a good bunch of peeps and can help you out with just about any question you have with liners. Drop over for coffee again if you want. Good to see that you have finally got your hands on a GREAT car hehehe ENJOY. See ya at the show.
:band:
Aidwin - most of us there will be with Black 33's or in Tufas case a Black 34 ......... go the Black lines :(
I'll be the girl ..... the tall one .....
Hey gods gift,
nice of you to introduce
dont be a stranger at the stand
it will be annoying like when we go on cruises and ppl stand with their mate and pretend like the other 4000000 skylines parked in the carpark dont exist
anyways i will meet you there. and people i am so pissed i cant have my line parked outside *sniff*. maybe Tim will park it there for me.
lata
RiaZ
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
