The car is riding on the standard suspension, so it hasnt been lowered, i might see if running 0 deg of camber helps, the odd thing is it is only happening on the left side, the right is fine and the camber numbers are similar.
https://www.sau.com.au/forums/topic/26998-uneven-tyre-wear/#findComment-575190
255's on the back and 235's on front. These shouldnt contribute to it should they??? Still seem fine on the right side, its just the left??????? Will rotate tyres from left to right and see if it still occurs on the same side otherwise it might be wheel/ tyre related if it doesnt...... dont think this would be the case though.
https://www.sau.com.au/forums/topic/26998-uneven-tyre-wear/#findComment-578398
