You would require a machinist to fabricate a dummy VCT or at least something that matches the cam seals and spend lots of money in the process.
If you really don't like the VCT, just disconnect the solenoid.
Umm, I just used a bolt and a little RTV for good measure.
I was thinking the VCT was recessed into the head and the seals were matched to that. i looked at a photo and that is not the case. But it would leak out the front of the cam.
What gear did you use and what about a knock pin? I assume you applied the RTV to the cam face.
Why did you remove yours?
Edited by M E S O G L E A
    • Yep that's a superb price and ther is no way you will over capitalise on you investment.  As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
