Cold Air Intake.
Basically the factory air box with panel filter is removed and replaced with a pod filter. An enclosure is made for the pod filter to shield it from heat and reduce heatsoak. To get the most out of it a cold air feed usually from the front bar runs up into the air box.
The result is a high flowing air filter that gets fresh cold air which assists in making more power.
There are short ram air filters where the pod filter itself is positioned low behind the front bar and cold air is rammed into the pod, but the issue with this is the potential to suck up water during wet weather.
How effective are these are making power? It was my understanding that a stand alone pod is probably worse than the stock airbox in our climate. As such I've been trying to source a stock box for my Supra. I'd considered making a heatshield, but figured the gain would be minimal, especially on a non turbo.
Does the actual intake pipe help much? What sort of gains can be expected, like 5kw?
I left my airbox in my R34 N/A and just took the top off it, so the air comes in normally and comes out through the airbox into my pod filter and the difference is fairly noticeable.
On an N/A the power gains are had through relieving restrictions. Getting cooler air into the engine efficiently, and exhaust gasses back out just as efficiently, finding the best compromise between top end power, and low end response. As such it takes a lot of modifications to get any decent power, but in the end every bit counts, just don't expect a huge gain just from a high flowing filter and cold air feed unless you combine it with other breathing mods, or unless of course if your current air filter is badly clogged and soaking up plenty of hot air that changing a filter alone will make a difference.
In a lot of cases a factory air box with high flow panel will be more beneficial than an unshielded pod.
What I've known some people do as well is run a cold air feed into the factory air box. Basically you get the benefits of a high flow filter, cold air, and OEM box designed to keep hot air out, and it's going to be well sealed in comparison to aftermarket/custom heat shields.
As for the intake pipe, if you experience high engine bay temps, then yeah a cold air feed to the filter will definitely help. Cooler air = higher density = more air in the engine = more power.
It may not be a HUGE amount more power, but if you compare that to say an unshielded pod, when the engine bay heats up and the pod filter sucks in hot air and has less power, the filter shielded from hot air that is also taking in cooler air from outside will be making more power in comparison and for longer.
I'm not sure how well the Supra factory airbox/snorkel flows, but if it's anything compared to say an R34, then a factory airbox and high flow panel is certainly a better way to go, unless you like to spend the time/dollars on a good CAI setup just to have a nice induction sound...
Jack's idea isn't too bad actually.. on the R34 the snorkel feeds air from the opening in the bonnet and is a fairly decent size. Even if there's a bit of heat soak it won't be so bad with the cold air running to the underside of the pod.
I wouldn't mind seeing a photo of that setup, mainly to see if it would be feasible to have a heat shield on the pod, one of the metal types that covers the top side of the pod and leaves the underside open. Not sure how good that would look though but at least it would minimise the heat being taken in and encourage suction from the cooler side of the pod.
Another set up that I've seen utilise the factory snorkel in combination with the pod filter is here: http://www.skylinesaustralia.com/forums/In...od+filter+setup
go down to your local plumbing joint recee or purple pig etc etc and ask them for heat resistant and bend into shape stuff
i got 2.25'' piping from from purple pig for $18 only needed about half but they only sell buy the metre
I'll get a pic for you, but it was the easiest way I thought, instead of getting induction piping and all that. I'd rather a heat sheald on it, but what can I make it out of? or where can I buy one?
you can buy el cheapo shiny plastic stuff from supercheap / autobarn that dont do jack
or go to bunnings and get a sheet of metal ($3-8) and make your on enclosure
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
