Hey,
anyone know where i may be able to get rust fixed ?
i got surface rust and rust ontop of my strut towers. want to get it looked at soon.
anyone had bad rust fixed or know of anyone that does restorations ?
need to be pointed in the right direction .... Thanks
TJ
https://www.sau.com.au/forums/topic/270060-rust-repair/
quick update, took it down to PJ Panels, Popes Rd Keysborough.
he quoted $700 if its just the top plate and suface rust on the strut tower itself. Or $1000-1200 if the strut tower is rusted through, leaving the engine in and just dropping the suspension.
:D pretty happy with that, will be getting onto that around August when money is kinda free'd up abit.
i will post after snaps and quality of work once completed.
https://www.sau.com.au/forums/topic/270060-rust-repair/#findComment-4597759
Looking at those photos, if this were my car I'd be getting to him to strip the panit off most of the area shown in those photo's because I can see paint bubbling and rust spots well away from the obvious rust areas near the shock mounts. Also the big rust areas could be associated with cracking of the shock tower probably caused by load transfer from the strut brace. Hopefully the repairer knows what he's doing.
https://www.sau.com.au/forums/topic/270060-rust-repair/#findComment-4598817
yeah he's taking the whole plate off.
and sanding the surrounding area's. if he see's bubbles he's gonna sand them back and inspect and treat.
he pointed out a few spots that i didnt see near the ABS behind the strut. he's a restors cars also so he know's his way around rust :(. i have faith
https://www.sau.com.au/forums/topic/270060-rust-repair/#findComment-4599090
if your keen on a second opinion Take it down to Micolour, 7 Dissik St Cheltenham
Already been nagging him to go see Michael. I was more than satisfied with my repair work done there, and it will be back for pre-sale touch-ups!
https://www.sau.com.au/forums/topic/270060-rust-repair/#findComment-4599593
rust is caused by moisture.
picture engine bay strut towers, unpainted i belive. then some braniac comes with an idea. lets weld a metal plate over each side for extra stiffness.
they do, and then they paint. and now what ever moisture has built up between those plates through hot and cold conditions, (not to mention the amount of salf the japs use on there roads to clear snow)
is rusting its way out. im hoping its only rusted up, but i doubt it, i got knocked back from one place saying it would be ' financially impossible' .
if it cost's more well then the trusty credit card may get used.
and Freddy, there was a little strain at the show and shine, but before hand i used Cutters (cut and polish stuff) to spiff up the engine bay, ever sinces then it has gotten worse :P
https://www.sau.com.au/forums/topic/270060-rust-repair/#findComment-4609076
Just wondering, is it caused by structural fatigue due to hard cornering etc?
but i have no rust and my car is stiffer and older, and driven harder i recon... rust is caused by oxidization, maybe bad treatment from factory, or from a snowy area, being a stag
https://www.sau.com.au/forums/topic/270060-rust-repair/#findComment-4609259
    • Nah, if I need to fit people in a car I'll just use the Mrs car, the MX5 is perfect for what I need as a fun little sports car for fun on the street As for getting in and out of the MX5, I have no issues as I am a short arse who does lots of mobility training 🥷 If anything, I have been looking at Daihatsu Hi-Jets for a work hack, I helped one of my mates move some stuff with one recently that he picked up from Just Jap, it was a little ripper and plenty big enough for what we needed, it would also be super handy for me as I do alot of gardening, and plan on having some veggie patches and native gardens in the place I buy next year when I retire I did alot landscape gardening and growing veggies prior to my current job, and loved it, and that is a hobby that can keep me sane in my retirement, and as such, the little 300kg load capacity would be more than enough for what I need it to move around I have been looking at utes for just this purpose for a while now, and a near new 2024 Hi-Jet can be had for under $30k And I would rather look at a quirky little Hi-Jet than pretty much any other little ute, well, apart from a Brumby, I love the little Brumby, and weirdly have never owned one yet I was going to buy a heap of raffle tickets to try and win the Brumby that MCM built for Subaru Australia, but sadly I totally missed the raffle, I even filled in some form to be told when the raffle started so I could buy tickets, but to my dismay I was never contacted and found out I missed it when I was randomly googling Brumbys last year... #conspiracy  Maybe I should just buy a Brumby for a little "work hack".....LOL I use to be indecisive, but now I'm not sure
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
