Hi
EOI at this stage but thinking about selling off my turbo kit as I am wanting to go to a low mount setup or would consider swapping for a decent sized low mount setup if it came with everything required for installation
Complete kit to suit SR20, consists of the below parts
-HKS 2835 turbo
-HKS stainless high mount manifold, neatly heat wrapped in heat tape
-TRUST/GREDDY external waste gate
-Custom 3.5" dump pipe to a 3.5" GREDDY front pipe
-Custom screamer pipe behind passenger wheel
-XTR turbo head bag
-Intercooler pipe from turbo to passenger guard (can use your existing intercooler pipe from here)
Will throw in intake pipe as well with joiners so you can run a Z32 AFM, will sit all neat in the bay. Pretty much everything you need to get it bolted up and running perfect, will just need to either get your own braided lines or use your existing ones if they reach. Just bolt it all on, bolt on your existing cat back and your set
This turbo kit on my built SR20 made 283rwkw @ 1.31 bar on Status Tuning dyno. It makes full boost, 1.31 bar by 4,400 RPM which is pretty decent considering the size of this turbo. Holds easily all the way up top red line and beyond. Have dyno graphs to show all results, you wouldn't want to run any more boost than that unless your upgrading the spring in the external gate
Doesn't feel laggy and is pretty streetable, once it's on boost it lights up whatever is on the rear from 1st through to 3rd, can even spin 4th if you try hard enough
Turbo kit is still on the car so can show working for those interested, will only remove once I have a deposit. Not sure on how many km's but all in perfect condition and working order, minimum to no shaft play, doesn't smoke or burn any oil
GENUINE INTEREST ONLY, don't look if you don't have cash, don't offer if you don't cash. Prefer if you PM or call/SMS me rather than posting in the thread, have more pictures for those who are interested
PM or call/SMS 0416 623 381
Located in Melbourne, south eastern suburbs - Dandenong area
Thanks
Had heaps of interest, price is set at $2,200 including braided oil and water lines
Complete kit, with everything required for installating and to get the car running
Thanks
Will consider reasonably offers or willing to swap for the following
2871R with adjustable actuator
Standard SR20 manifold
Braided oil and water lines - Suit S13 motor
Dump pipe - Suit S13
3" front pipe - Suit S13
Intake pipe to suit Z32 AFM
Thanks
ร—
ร—
