my clutch is f.u.c.k.e.d
it shat itself today. have to rev to like 6k before it starts biting
i want to go to nissan tomolo to buy the nissan patrol clutch which was mentioned in that other thread. Part no: R173N
Nissan Patrol clutch
i jus want to confirm if this is the right clutch and that it will fit my car (94 R33 GTST)
and jus to clarify, which year patrol model is the clutch from just in case the jockeys at nissan ask.
also anyone know where i can get it installed cheaply? or a place where i can use a hoist? (not too far from springy area as i dun think my clutch can last the distance)
also what gear box oil should i buy to refill?
god dammit clutches are freakin annoying when they fu(k up. :rofl:
please any help is appreciated.
https://www.sau.com.au/forums/topic/27011-clutch-is-fubared/
LOL nissan patrol clutch is exactly the same.If you want a clutch ring paul at precision brake and clutch in bendigo he's built clutches for most top street and strip cars in australia and neighbouring countries.for ex..526rwkw supra single plate. he can be reached on 54436744 or 0427436744
https://www.sau.com.au/forums/topic/27011-clutch-is-fubared/#findComment-569256
Oh yeah its not cheaper unless you are buying genuine nissan parts.This bloke is well worth it,5 mins out ya time hand made button paddle clutch.or full face.dont forget pressure plate has alot to do with it aswell.A crappy clamp load pressure plate is gonna suck on a turbo line.
https://www.sau.com.au/forums/topic/27011-clutch-is-fubared/#findComment-569288
good work.. hopefully it goes well. I reckon there are a stack of places that can do it on the cheap - a clutch install is a clutch install.
prolly a good idea to get the flywheel machined as well when you get it all done, as that will improve the hookup of the new clutch.
damn Nissan - they build the gearboxes to withstand 300rwkw, and yet they only build the clutch to only 160rwkw or so :(
https://www.sau.com.au/forums/topic/27011-clutch-is-fubared/#findComment-569463
Originally posted by predator666 damn Nissan - they build the gearboxes to withstand 300rwkw, and yet they only build the clutch to only 160rwkw or so :( [/b]
i thought you knew better mr gordon!
It's much preferreable to have one's clutch let go than to strip the gearbox.
hence why you sohuld have you clutch slightly less than what your box can handle so the clutch will go first.
Much cheaper option. :uh-huh:
https://www.sau.com.au/forums/topic/27011-clutch-is-fubared/#findComment-569579
ok
jus bought the clutch from repco, was $236.95
PBR clutch kit
dun say anything about being a heavy duty daiken
but i can tell yah its weighs a bit
now i gotta find a muzza to put it on for me
the muzza at SLR performance centre in springy said 250 machine the flywheel and gearbox oil
other muzza said he will have to see but about 100 something depending on condition of the clutch
which muzza should i pick
https://www.sau.com.au/forums/topic/27011-clutch-is-fubared/#findComment-569846
Do you have to drop the k frame to the end of the threads to get to top bell housing bolts??.if so thats damn cheap coz its a prick of a job.I would go with oil and machine for $250.then its gonna feel brand new.And if ya can pay the difference get that redline shockproof oil.
https://www.sau.com.au/forums/topic/27011-clutch-is-fubared/#findComment-569946
yes, but ~160rwkw and around 300rwkw are largely different figures!
yes, but also, little japanese man dont like pushing a decent heavy/grippy clutch all day long either :shake: :shake:
Also im betting most of you still have the same clutch from factory... so they are getting a little older now too
https://www.sau.com.au/forums/topic/27011-clutch-is-fubared/#findComment-569980
When you get old clutch out check for wear on the plate.If its severley worn on pressure plate side its driver wear slipping and riding it.If its severley worn on flywheel side its engine power wear.
My twin plate was definitely the best mod ive done so far never thought a clutch would make my car feel so positive in launch and hard changing.To anyone else upgrading your clutch get the best you can afford as it makes such a good difference.
https://www.sau.com.au/forums/topic/27011-clutch-is-fubared/#findComment-570002
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
