Clutch is FUBARED
chopobo
 Share
my clutch is f.u.c.k.e.d
it shat itself today. have to rev to like 6k before it starts biting
i want to go to nissan tomolo to buy the nissan patrol clutch which was mentioned in that other thread. Part no: R173N
Nissan Patrol clutch
i jus want to confirm if this is the right clutch and that it will fit my car (94 R33 GTST)
and jus to clarify, which year patrol model is the clutch from just in case the jockeys at nissan ask.
also anyone know where i can get it installed cheaply? or a place where i can use a hoist? (not too far from springy area as i dun think my clutch can last the distance)
also what gear box oil should i buy to refill?
god dammit clutches are freakin annoying when they fu(k up. :rofl:
please any help is appreciated.
LOL nissan patrol clutch is exactly the same.If you want a clutch ring paul at precision brake and clutch in bendigo he's built clutches for most top street and strip cars in australia and neighbouring countries.for ex..526rwkw supra single plate. he can be reached on 54436744 or 0427436744
Oh yeah its not cheaper unless you are buying genuine nissan parts.This bloke is well worth it,5 mins out ya time hand made button paddle clutch.or full face.dont forget pressure plate has alot to do with it aswell.A crappy clamp load pressure plate is gonna suck on a turbo line.
good work.. hopefully it goes well. I reckon there are a stack of places that can do it on the cheap - a clutch install is a clutch install.
prolly a good idea to get the flywheel machined as well when you get it all done, as that will improve the hookup of the new clutch.
damn Nissan - they build the gearboxes to withstand 300rwkw, and yet they only build the clutch to only 160rwkw or so :(
Originally posted by predator666 damn Nissan - they build the gearboxes to withstand 300rwkw, and yet they only build the clutch to only 160rwkw or so :( [/b]
i thought you knew better mr gordon!
It's much preferreable to have one's clutch let go than to strip the gearbox.
hence why you sohuld have you clutch slightly less than what your box can handle so the clutch will go first.
Much cheaper option. :uh-huh:
ok
jus bought the clutch from repco, was $236.95
PBR clutch kit
dun say anything about being a heavy duty daiken
but i can tell yah its weighs a bit
now i gotta find a muzza to put it on for me
the muzza at SLR performance centre in springy said 250 machine the flywheel and gearbox oil
other muzza said he will have to see but about 100 something depending on condition of the clutch
which muzza should i pick
Do you have to drop the k frame to the end of the threads to get to top bell housing bolts??.if so thats damn cheap coz its a prick of a job.I would go with oil and machine for $250.then its gonna feel brand new.And if ya can pay the difference get that redline shockproof oil.
yes, but ~160rwkw and around 300rwkw are largely different figures!
yes, but also, little japanese man dont like pushing a decent heavy/grippy clutch all day long either :shake: :shake:
Also im betting most of you still have the same clutch from factory... so they are getting a little older now too
When you get old clutch out check for wear on the plate.If its severley worn on pressure plate side its driver wear slipping and riding it.If its severley worn on flywheel side its engine power wear.
My twin plate was definitely the best mod ive done so far never thought a clutch would make my car feel so positive in launch and hard changing.To anyone else upgrading your clutch get the best you can afford as it makes such a good difference.
ok im gonna get it fitted tomolo morning
ill let you know on the results
ill be the test guinea pig
then if its good we all know patrol clutch is a good cheap alternative to buying expensive clutches
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
