holy plough-understeer todaman! is that car trying to kill you or is it the other way 'round???
  Adz said:
Lol at the Toda vid thats awesome
Circuit: Sandown Raceway VIC
Car: R32 GTSt
Driver: Me Adam Newton
Lap time: 1.19.66
Camera: Sony 1080i HDR-HC7, IO Port Racing Camer Mount
Link:
unreal! :)
Car: R32 GTSt
Lap time: 1.19.66
Link:
thanks for sharing. great vid! :)
Car: R32 GTSt
Lap time: 1.19.66
Link:
Man, that is some acceleration.
Not really for this thread but - Abit of update, very disappointed this weekend.
Getting the car ready for Round 5 of the NSW SS Championships, stripped the engine for a freshen up, put new head gaskets in (some supposedly really good sodium filled head gaskets). Got it tune'd on the Dyno, made good power.
Some time later, started it up to load it on the trailer and the engine shat itself.
Looks like the new head gasket gave way and now I have soup in the sump.
There goes any further chance to defend the class championship - not sure if I have sufficient funds to fix the engine in time for next round.
Looking back, its been a wild ride:
Racing in Year 1 - First time ever driving a car on the track - 2nd place Class 3A
Class 3B Champions in Year 2
Hopefully, I get more chances in future to continue to drive competitively, now, I'm just feeling tired...
Edited by e240
Circuit: Barbagallo Raceway
Car: Mazda RX7 FD Series 6
Tyres; Bridgestone RE55, 225/50/16
Driver:Ashly Barnett
Time: 1.01.10 (my best qualifying lap of 2008)
Camera: POV1
Interesting race, started rear of field in reverse grid race. Ended in a crash, but the camera stopped 1 corner before the crash. Lookout for the missed gear on the first lap, this how to damage a PPG Dog Box.
To watch the race from the other 3 cars including the crash go to this link.
Ash
  PSI Parts said:
I'm getting the Go Pro Motorsport Wide next week, so should have some video from Wakefield on 28th July. Speaking of which, if anyone is going make sure you come say hi.
i picked one up on friday and had a play on saturday with it at Wakefield. It wasn't too happy mounted on the rear parcel shelf due mainly to the light difference from inside to outside so i'll be mounting it to the dash for future events. I did a couple of sessions with it stuck to the drivers rear 1/4 window and they came up ok.
bit of a slow session here 1:10s-1:11s at best with the camera on the 1/4.
bit cranky i didn't get my last session with the 1:09 as i had to copy everything off the sd card and it took too long to get it off between sessions. 15min of vid is about 500meg and the max it can use is a 2 gig card. Might have to invest in a second card for future.
  hrd-hr30 said:
last session from Lakeside yesterday in my ~200rwkw Sil80. PB lap of 59.87 is the first lap on the video. Still needs some more suspension sorting, so it should get a bit quicker yet.
Geez shes a bit loose in the rear end....10 points for holding on to it :D
That was great driving, i can see why lakeside requires alot of skill to go fast.
Thought I would put a couple up :)
Circuit: ORAN PARK GP 2008 SUPERLAP
Car: TURBO HONDA S2000
Driver: JOHN BOSTON
Lap time: 1:17.20
Camera: NOT SURE
Link:
Circuit: 2009 ROYAL EASTER SHOW SYDNEY
Car: TOYOTA HILUX V6
Driver: JOHN BOSTON
Lap time: Who gives a !! lol
Camera: NOT SURE
www.V6Hiluxheroes.com.au
Link:
Edited by Bozman1
    • She swallowed the spider to catch the fly.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
