holy plough-understeer todaman! is that car trying to kill you or is it the other way 'round???
  Adz said:
Lol at the Toda vid thats awesome
Circuit: Sandown Raceway VIC
Car: R32 GTSt
Driver: Me Adam Newton
Lap time: 1.19.66
Camera: Sony 1080i HDR-HC7, IO Port Racing Camer Mount
Link:
unreal! :)
Car: R32 GTSt
Lap time: 1.19.66
Link:
thanks for sharing. great vid! :)
Car: R32 GTSt
Lap time: 1.19.66
Link:
Man, that is some acceleration.
Not really for this thread but - Abit of update, very disappointed this weekend.
Getting the car ready for Round 5 of the NSW SS Championships, stripped the engine for a freshen up, put new head gaskets in (some supposedly really good sodium filled head gaskets). Got it tune'd on the Dyno, made good power.
Some time later, started it up to load it on the trailer and the engine shat itself.
Looks like the new head gasket gave way and now I have soup in the sump.
There goes any further chance to defend the class championship - not sure if I have sufficient funds to fix the engine in time for next round.
Looking back, its been a wild ride:
Racing in Year 1 - First time ever driving a car on the track - 2nd place Class 3A
Class 3B Champions in Year 2
Hopefully, I get more chances in future to continue to drive competitively, now, I'm just feeling tired...
Edited by e240
Circuit: Barbagallo Raceway
Car: Mazda RX7 FD Series 6
Tyres; Bridgestone RE55, 225/50/16
Driver:Ashly Barnett
Time: 1.01.10 (my best qualifying lap of 2008)
Camera: POV1
Interesting race, started rear of field in reverse grid race. Ended in a crash, but the camera stopped 1 corner before the crash. Lookout for the missed gear on the first lap, this how to damage a PPG Dog Box.
To watch the race from the other 3 cars including the crash go to this link.
Ash
  PSI Parts said:
I'm getting the Go Pro Motorsport Wide next week, so should have some video from Wakefield on 28th July. Speaking of which, if anyone is going make sure you come say hi.
i picked one up on friday and had a play on saturday with it at Wakefield. It wasn't too happy mounted on the rear parcel shelf due mainly to the light difference from inside to outside so i'll be mounting it to the dash for future events. I did a couple of sessions with it stuck to the drivers rear 1/4 window and they came up ok.
bit of a slow session here 1:10s-1:11s at best with the camera on the 1/4.
bit cranky i didn't get my last session with the 1:09 as i had to copy everything off the sd card and it took too long to get it off between sessions. 15min of vid is about 500meg and the max it can use is a 2 gig card. Might have to invest in a second card for future.
  hrd-hr30 said:
last session from Lakeside yesterday in my ~200rwkw Sil80. PB lap of 59.87 is the first lap on the video. Still needs some more suspension sorting, so it should get a bit quicker yet.
Geez shes a bit loose in the rear end....10 points for holding on to it :D
That was great driving, i can see why lakeside requires alot of skill to go fast.
Thought I would put a couple up :)
Circuit: ORAN PARK GP 2008 SUPERLAP
Car: TURBO HONDA S2000
Driver: JOHN BOSTON
Lap time: 1:17.20
Camera: NOT SURE
Link:
Circuit: 2009 ROYAL EASTER SHOW SYDNEY
Car: TOYOTA HILUX V6
Driver: JOHN BOSTON
Lap time: Who gives a !! lol
Camera: NOT SURE
www.V6Hiluxheroes.com.au
Link:
Edited by Bozman1
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 馃ゴ
    • Most of the R33 GTST S1 are all like "airbag? What airbag?!"
